What exactly is this leak? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 11-04-2016, 01:46 PM Thread Starter
Bike has been sitting for about 2 weeks and I just noticed a small leak dripping onto the rear wheel. I know I can dig into it and more than likely figure it out but figured there are some of you that know these bikes inside an out that will know more in 2 seconds than I would in 30 minutes of trying to play mechanic.
What are your thoughts? It's dripping from where the arrow is.
Reckoning is offline
post #2 of 14 (permalink) Old 11-04-2016, 02:31 PM
there should be no oil in that area of the rear end. its probably leaking from engine area (it looks like engine oil), and running back to that point to drip
michiganteddybear is offline
post #3 of 14 (permalink) Old 11-04-2016, 02:52 PM
...or the final drive seal
post #4 of 14 (permalink) Old 11-04-2016, 03:05 PM Thread Starter
Is there oil contained here in the green circle because I ran my finger over the orange circled area and it's not running down from there. Seems to be coming out at the green circle.
post #5 of 14 (permalink) Old 11-04-2016, 03:14 PM
final drive is other side,I'm so" stupid" sometimes.no no oil should be coming from there.there should just be a bolt and a bushing,as that is the rod that keep the brake assembly from spinning around when you hit the rear brake.
post #6 of 14 (permalink) Old 11-04-2016, 03:28 PM Thread Starter
Upon further review, it appears it is leaking from here! I believe it's coming down from the shock.
post #7 of 14 (permalink) Old 11-04-2016, 03:32 PM Thread Starter
Uhm... wow.
post #8 of 14 (permalink) Old 11-04-2016, 03:34 PM
ebay
post #9 of 14 (permalink) Old 11-04-2016, 03:42 PM Thread Starter
Can you do anything to fix a leaking shock or is it pretty much a must-replace scenario?
post #10 of 14 (permalink) Old 11-04-2016, 04:07 PM Thread Starter
Found 1 used shock off a 94. Would you guys throw 1 replacement on or would you always replace them in pairs?
