Torque Values - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 09-14-2016, 02:01 PM Thread Starter
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
Torque Values
Anyone know the torque value for the front axle nut?
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
National Cycles Low Boy Heavy Duty windshield
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Progressive 412 shocks
Chris and Shim is offline
post #2 of 10 (permalink) Old 09-14-2016, 02:22 PM
uhhh, tight?
michiganteddybear is offline
post #3 of 10 (permalink) Old 09-14-2016, 02:35 PM
Alpha Geek
Hexadecimus's Avatar
43 axle, 9.5 pinch bolt?
Hexadecimus is offline
post #4 of 10 (permalink) Old 09-14-2016, 04:47 PM Thread Starter
Huh? There's only one nut on the axle.
Luggage rack
post #5 of 10 (permalink) Old 09-14-2016, 06:08 PM
I believe it's 43 ft/lbs..
Did you look here?:
https://www.vn750.com/forum/11-vn750-...ue-values.html
post #6 of 10 (permalink) Old 09-15-2016, 12:03 PM
yup one on axle.pinch bolt is on lower fork where the axle goes through,holding axle in place
post #7 of 10 (permalink) Old 09-15-2016, 12:34 PM
pro tip.. tighten pinch bolt first!
post #8 of 10 (permalink) Old 09-15-2016, 03:13 PM
Chips episode where they loosen bolts to sabotage Ponch./ I caught it right away. They didn't loosen the pinch bolt so nothing would have happened.
"CHiPs" Dog Gone (TV Episode 1977) - IMDb
Goofs
Neither the KZ900 or 1000 police motorcycles used hex nuts as shown to retain the front axle. Parts catalogs for both motorcycles list round headed collars that thread onto the axle and then are retained by pinch bolts on the bottoms of the forks. Since the pinch bolts were never loosened, it would not be possible for the axle to come loose as shown. In the event the axle did fall out, the entire front wheel would detach resulting in an immediate crash, not the wobbly wheel as shown. See more
post #9 of 10 (permalink) Old 09-15-2016, 04:34 PM
yea, I always did laugh at that episode.. even way back when in the time when I didnt own a motorcycle..
the axle isnt gonna slide outta them forks...
post #10 of 10 (permalink) Old 09-17-2016, 04:45 PM
just watched the part where the 2" long axle falls out
