HELP! Any ideas??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 15 (permalink) Old 08-26-2016, 10:42 PM Thread Starter
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
Exclamation HELP! Any ideas???
Ok, I've started on swapping my tires and am in the process of doing the front one now. The new tire is on the rim BUT: The beads of the tires won't pop outward enough to hold air. Half the tire is fine, pressed up against the wheel, but the other half of the tire has the beads running down the centerline of the rim. It won't hold air. Any suggestions on how to handle this?
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
National Cycles Low Boy Heavy Duty windshield
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Progressive 412 shocks
Chris and Shim is offline
post #2 of 15 (permalink) Old 08-26-2016, 11:32 PM
Lots of dish soap and a high pressure air supply. A ratchet strap around the tire to help push it open helps. The rim has to be squeaky clean. 50/50 mix of dish soap and water to lube the tire and rim...
When I worked in a bike shop, we'd use a half dozen or so wood dowels to open up the gap between tires we planned to mount. A day in the sun, or next to a heater for a few hours would "re-set" a tire whose gap was too small.
post #3 of 15 (permalink) Old 08-26-2016, 11:34 PM
Soak bead with dish soap.take a tiedown strap and put around tire and sinch it in to push bead out into rim.also make sure the dot on the tire is lined up with valve stem.then pump up.bead should set.can also bounce the tire where it isn't seating.
post #4 of 15 (permalink) Old 08-26-2016, 11:39 PM
Ratchet strap around the center of the tread.
Or do the ether trick. Tends to scare people though. Best to deflate and re-inflate after doing the ether trick, don't want flammable air in your tire.
post #5 of 15 (permalink) Old 08-26-2016, 11:46 PM
If you don't have a ratchet type strap, you can tie a strong rope around the tire, and tighten it up by twisting it with a rod.
OleDirtyDoc likes this.
post #6 of 15 (permalink) Old 08-27-2016, 12:40 AM Thread Starter
Thanks. I'll go out and try some of this right now.
Luggage rack
post #7 of 15 (permalink) Old 08-27-2016, 01:06 AM Thread Starter
No-go, so far. I tried bouncing it, using the 50-50 soap/water solution, and discovered that my ratchet tie down straps won't go that tight by a good 5 inches. I'll see what happens if I put a 2X4 block under the strap to tack up that slack............ more to come........
Luggage rack
post #8 of 15 (permalink) Old 08-27-2016, 01:09 AM
Don't cut the soap...get a smaller tie strap...
post #9 of 15 (permalink) Old 08-27-2016, 01:31 AM Thread Starter
I think I have some rope somewhere in the garage but I'll look for it tomorrow. Its 90 degrees in there right now. Tomorrow is supposed to be in the mid 70s and much more conducive to me sticking with it. Perhaps it'll just pop out by itself overnight. (One could only wish.) If, after all my trials and tribulations don't work, I'll just take it to the local Honda/Yamaha shop and have them rescue me. They'll work on the front tire but not the back. Well, they said they wouldn't remove it from the bike but I suppose I can see if they'll do it if I remove it. The nearest Kawasaki shop is, well.... it's not close and frankly they're grade A jerks, to boot. This is my first effort to change a tire myself on a bike and frankly it may be my last.
Luggage rack
post #10 of 15 (permalink) Old 08-27-2016, 10:14 AM
try taking just the tire to any local auto garage/tire shop. especially if its NOT a chain store.. throw a 5 or 10 at them, most will probably take care of ya.
with the equipment they have, its seriously going to be less than 5 mins work for them to seat the bead.
michiganteddybear is offline
