Size of axles?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 08-21-2016, 09:01 PM Thread Starter
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
Question Size of axles??
I'll be swapping out and balancing my tires this coming up weekend. I was contemplating designs for my wheel balancing set-up when I realized that I don't know the size of the axles for this thing. I do have a threaded pipe that I can easily secure to a sturdy fence post on one end and use a drilled out 2X4 to hold up the other end when it is under "load". The pipe is 7/8ths on an inch across. But I don't know if this is too thick or not. I do have a non-threaded 5/8ths of an inch pipe that can be used if necessary. Anyone know if these would work?
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
National Cycles Low Boy Heavy Duty windshield
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Progressive 412 shocks
Chris and Shim is offline
post #2 of 8 (permalink) Old 08-21-2016, 09:06 PM
If I remember correct there's axle sizes in this thread
https://www.vn750.com/forum/showthread.php?t=24044
post #3 of 8 (permalink) Old 08-21-2016, 09:45 PM Thread Starter
So, if I am reading that chart correctly the front inside diameter for the bearings are 25mm or 0.98425... inches. The rear inside diameter for the bearings are 28mm or 1.1 inches. Therefore my 7/8ths thick pipe should work. Cool. Thanks ODC.
Luggage rack
post #4 of 8 (permalink) Old 08-29-2016, 12:54 AM Thread Starter
Incidentally, this info really didn't work like I thought it would. The front axle is smaller than the ID of the bearings. I wound up just using the actual axle to balance the wheel instead of either of the pipes I had.
Luggage rack
post #5 of 8 (permalink) Old 08-29-2016, 09:24 AM
That's what I was going to say, why aren't you just using the axle for that wheel?
If you use a smaller diameter rod, it might not engage the bearings properly. I always balance wheels with their own axles....
post #6 of 8 (permalink) Old 08-29-2016, 11:10 PM
It's not the size that matters...
post #7 of 8 (permalink) Old 08-30-2016, 09:25 AM
The lie women tell men who are small........
post #8 of 8 (permalink) Old 08-30-2016, 10:27 AM
The lie men tell women who are big...
