Ordered tire from motorcyclesuperstore - already 3 years old - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 05-30-2016, 04:49 PM Thread Starter
Motorcyclesuperstore sent me a tire with a date code of 2913 that's almost three years old already! Am I nuts for thinking that's not appropriate to sell or is it common? Would you use a NOS tire that's 3 year into shelf life?
I went a little cheap with the shinko tourmasters knowing the wear reputation.. The front has quite a bit of flashing on lettering etc., compared to the rear tire. Not super impressed.
2002 vn750
AGM battery, Shinko 230 tires oversized front
Ear shaved - k&n pods, drilled clutch basket
40/138 jetting
If I can split a case and make it work - you can too!
Forum pictures:http://s150.photobucket.com/user/Gid...?sort=3&page=1
gidaeon is offline
post #2 of 11 (permalink) Old 05-30-2016, 06:48 PM
Tinkerer
Gaz73's Avatar
You should be ok with the rear, from memory I think 5 years storage is the cut off point.
Man can not live by bread alone... he needs Duct tape & WD40
Gaz73 is offline
post #3 of 11 (permalink) Old 05-30-2016, 07:04 PM Thread Starter
The rear was only 8 months old, its the front that is 3 years.
Does that make a difference?
2002 vn750
40/138 jetting
gidaeon is offline
post #4 of 11 (permalink) Old 05-30-2016, 07:48 PM
About five years so you should be OK.
post #5 of 11 (permalink) Old 05-31-2016, 12:05 AM
cglennon's Avatar
The last time I ordered tires online (Metzler ME 880s) I called and had the rep. physically go out to the warehouse and read me the tire manufacture birthday dates on the tires that I would be receiving. They were six (rear) months and nine (front) months old. For me, less than a year old is acceptable, since I am am an old Yankee and frugal (i.e., want to maximize my investment or maybe just cheap).
You have about 2 years usable life in your front tire (before dry rot sets in). If you went cheap, then you may be good with that.
Chris Glennon - Portland, OR
cglennon is offline
post #6 of 11 (permalink) Old 05-31-2016, 01:43 PM Thread Starter
Tried to call and do an exhange/return but mc superstore just said "because we have multiple warehouses we cant check or guarantee anymore" said they used to be able to check ..and a line about this being their busiest day of the year...
Not impressed.
Guess i am using it but not recommend mc superstore to people.
gidaeon is offline
post #7 of 11 (permalink) Old 05-31-2016, 03:06 PM
Not impressed.
Do they still have their guarantee in writing on their webpage?if so they are legally required to fulfill their guarantee
post #8 of 11 (permalink) Old 05-31-2016, 03:11 PM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
Interesting thread. I had not given this any thought before about age of tires when I first get it. I'm looking to change mine out once I get enough extra cash put away to cover the tires, installation, and a spline lube. This thread started me thinking. Now my question about this: "Storage time", does this eat into "on-bike usage time"? I'll probably never put enough mileage on tires so as to wear them out. So my main replacement criteria will almost assuredly be time based. (The original tires I have on it now are waaaaaaay past replacement time.)
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
National Cycles Low Boy Heavy Duty windshield
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Progressive 412 shocks
Chris and Shim is offline
post #9 of 11 (permalink) Old 05-31-2016, 03:17 PM
Yes as the rubber ages as they are stored just like if they're on the bike.they do have a protective coating(THIS IS WHY YOU ARE SUPPOSED TO BE CAREFULL THE FIRST 100 OR SO MILES UNTIL THE COATING WEARS OFF,AS IT EFFECTS THE TIRES ABILITY TO GRIP.KIND OF LIKE IF YOU SPRAYED ARMOUR-ALL ON THE TREAD)but that still doesn't mean much
post #10 of 11 (permalink) Old 05-31-2016, 06:26 PM Thread Starter
I see no guarantee other than lowest price on their page. I escalated with a supervisor and got no where. Ill just use it.
They say 5yr shelf life and that they pull off shelf after 5 years is exceeded. I shared my opinion. Id go with bikebandit or another next time.
Still will be better than the 14 year old tires on it now with lots of tread "life"
gidaeon is offline
