How much weight can I carry? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 08-26-2008, 01:17 PM Thread Starter
Hey Guys I am a big guy(280lbs) 6'3. I want to ride with my fiance she is about 170ish(shell never actually tell me) But I read the manual and that will exceded the weight limit of the bik is there anything I can do??
tubaboy26 is offline
post #2 of 9 (permalink) Old 08-26-2008, 03:06 PM
Joem's Avatar
I am pushing 300 lbs and my wife is about 145. We have taken overnight trips with a loaded pack on the back. with no problems. I can't hardly tell she's back there. Dial up the preload on your rear shocks to 4 and make sure the air chambers are filled. You should do fine.
Joe McAdoo
Springfield, MO
[email protected]
VROC # 28175
Joem is offline
post #3 of 9 (permalink) Old 08-26-2008, 04:46 PM
Get a smaller fiance....or diet...
Seriously, the GVWR or whatever it is called for the bike says not to exceed 450 lbs. This is due to the tires of course not the bike itself.
You can pretty much load the bike up as much as you want, but you do risk damaging the tire or wearing it unevenly.
You may have seen photos of riders in Asia that have more or less built an entire house on their little scooters...so overloading a bike does not mean it will explode or something...
Keep the tires inflated to their "high" limit..32 rear and 30 front I think for stock tires...If you ride two up often you might want to get some heavy duty shocks, otherwise fill the stock ones with about 35 lbs of air (eash) and avoid pot holes.....
post #4 of 9 (permalink) Old 08-26-2008, 04:57 PM
750Doug's Avatar
Bigger bike.............................................. ....
somebody had to.
750Doug is offline
post #5 of 9 (permalink) Old 08-27-2008, 11:23 AM
VulcanRider08's Avatar
What PSI should I fill the rear shocks? I my wife and I each weigh 200 pounds. I've dialed up to preset 4 and the shocks are stiffer...what does the added air pressure do for me?
2003 VN750 "Vulberry"
Panama City, FL
VulcanRider08 is offline
post #6 of 9 (permalink) Old 08-27-2008, 11:57 AM
Glenn M's Avatar
43psi. is max
Glenn
1985 VN700
Saddle Bags
Small Sport Windshield
R/R moved
Home built coasters
Kaw touring front fender
1990 Fuel tank
Kenda Kruz 110/90-19 & 170/80-15 tires
NGK Iridium plugs
NGK plug caps and 7mm copper core wires.
Deer Whistles
My VN700 pic's
VROC #7740
Glenn M is offline
post #7 of 9 (permalink) Old 08-28-2008, 10:56 PM
she's gonna push you up on the tank.
grhoward
grhoward is offline
post #8 of 9 (permalink) Old 08-28-2008, 11:19 PM
Agreed. I'm 6'1" 235-ish and have ridden with my 14 year old son on the back, 6' and 185 pounds... VERY uncomfortable ride. I was straddling the tank and my back ached for a day afterward. Felt like when I have to drive my wife's car, I get in and she has the seat pushed forward against the wheel and the seat back is staright up and down, ouch!
rickoz is offline
post #9 of 9 (permalink) Old 08-29-2008, 06:58 PM
james brill's Avatar
get two 750's,ride together.
james brill is offline
