sticky calipers - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 8Likes
  • 4 Post By Spockster
  • 1 Post By WilliamTech
  • 1 Post By OleDirtyDoc
  • 2 Post By One1
post #1 of 9 (permalink) Old 04-23-2016, 11:11 AM Thread Starter
I'm a rider
One1's Avatar
sticky calipers
Mine are nearly closed up and holding the wheel tight after prying them apart and bleeding them the first time, they locked the wheel solid. What do I to to lube them or whatever is making them stick. They sat for a good while.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #2 of 9 (permalink) Old 04-23-2016, 12:03 PM
Have to remove the piston and clean the bore/piston.
Can also be a collapsing hose holding pressure.
post #3 of 9 (permalink) Old 04-23-2016, 12:33 PM
Good call !
.....sometimes they can collapse on the inside...not showing evidence externally.
One1 likes this.
post #4 of 9 (permalink) Old 04-23-2016, 12:58 PM
Originally Posted by WilliamTech View Post
Good call !
Definitely. I've dealt with a lot of collapsing brake hoses, none could be seen, it was all internal.
Can hit the brake a few times, release the brake, then open a bleeder and see if there's pressure in the line.
I always check for this when there's a complaint about gas mileage that's not easily solved.
Seems the 1988-2000 GM pickups are having this problem a lot lately.
post #5 of 9 (permalink) Old 04-23-2016, 02:18 PM Thread Starter
I'm a rider
One1's Avatar
i'll see what I can do. I bled them very well last night with new fluid and had no issues doing so. They were shooting fluid 2 feet when bleeding.
1981 KZ750
One1 is offline
post #6 of 9 (permalink) Old 04-23-2016, 03:01 PM
Good call !
My cb750 is doing that now
post #7 of 9 (permalink) Old 04-23-2016, 03:14 PM
If its a dirty piston sometimes they can be cleaned without disassembling the whole system. Take calipers off one at a time.pull pads off and take off rubber boot.put a c clamp on caliper and leave about a half inch.press brake lever until piston hits the c clamp.you will see a line of crud.clean with pb blaster and wire brush.collapse piston with c clamp past the line of crud.repeat process until no crud.then reassemble.and repeat on other side
One1 likes this.
post #8 of 9 (permalink) Old 04-26-2016, 08:52 AM Thread Starter
I'm a rider
One1's Avatar
Did exactly that. Lightly sanded one time and it worked fine.
OleDirtyDoc and calebj like this.
1981 KZ750
One1 is offline
post #9 of 9 (permalink) Old 05-02-2016, 10:42 AM Thread Starter
I'm a rider
One1's Avatar
Turned out to be the return valve on the master cyl not releasing pressure. This video shows proper operation after I removed it and cleaned it.
1981 KZ750
One1 is offline
