Valve Stem Issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 08-22-2008, 09:03 PM Thread Starter
Love My Baby
rubyrick's Avatar
Valve Stem Issue
Hi all. I recently bought a chrome right angle valve stem from Rick's Automotive. Just over $5 shipping included - check it out. I'm going to use it only when I inflate or check my rear tire pressure because my pressure gauge and tire pump don't fit on the rear tire. Worked well but some air escapes (about 1 psi) when you apply and remove the device (screw on, not quick connect).
When I first applied the angled valve stem, I noticed that my front tire valve stem was a 1-inch valve, and the rear tire valve stem is a 1.5 inch valve. Stupid, because there is less room on the rear tire to fit a pressure gauge or most air chucks. Is this stock? or did my mechanic replace the stock with a longer valve when I had my tire replaced after a flat?
Also, does anyone know of a good low profile rubber valve stem, say 1/2 inch protrusion, so that it would be easy to check the tire pressure or inflate the rear tire? I'll consider chrome stems if they're the only ones available.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #2 of 10 (permalink) Old 08-22-2008, 10:31 PM
Stock valve stems are the same length, about 1 inch. So someone put it in the longer one.
As you have to break the bead on the tire to install any valve stem, not sure why you just don't get a one piece 90 degree valve stem to start with. Like these:
http://tinyurl.com/6nx6bo
They are machined and a bit costly, but they do make cheaper ones..(just do not have a link)
Some RV places carry them I am told for a couple bucks.
I do not think they make a straight one smaller than the 1 inch stock stem, but if you do find one smaller let us know.
post #3 of 10 (permalink) Old 08-22-2008, 10:44 PM Thread Starter
Love My Baby
rubyrick's Avatar
Hey Knifemaker. Saw those on a previous post of yours. They're nice, but $$. There's a lot of disagreement on wether or not angled valve stems are a problem when going high speeds, something about the centrifugal force on the valve. I guess if the angle was pointing away from the direction of the tire spin and not towards the spin or out to the side, it shouldn't be a problem. But I've never had a problem with a straight rubber valve stem. I did find a low profile metal valve stem - see THIS one and THIS one. Looks good, I guess, but it may be too low to connect an air chuck to, I don't know. The 2nd one states you need to use a filler tube to connect an air chuck to.
Anyone use one of these low profile valve stems?
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
X
rubyrick is offline
post #4 of 10 (permalink) Old 08-22-2008, 11:38 PM
I bought some from Rick's recently myself, and I plan to use them only when I'm putting air in the tires. It takes all of 10 seconds to screw on or remove, and it makes it so much easier.
Harvey_birdman is offline
post #5 of 10 (permalink) Old 08-23-2008, 07:11 AM
750Doug's Avatar
Dennis Kirk sells 90deg. valve stems for about $17, they're silver, and delivery time is PDQ too.
Here's a link-
Right Angle Valve Stems
Order by 8pm and it ships the same day.
750Doug is offline
post #6 of 10 (permalink) Old 08-23-2008, 07:17 AM
750Doug's Avatar
Nevermind, at DK they're priced each, and the ones KM posted are a pack of two.
750Doug is offline
post #7 of 10 (permalink) Old 08-23-2008, 09:28 AM Thread Starter
Love My Baby
rubyrick's Avatar
Found a low profile rubber valve stem that might fit our bikes. Look HERE at the first product on the list. Looks like the total exposed length is under 1-inch.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
X
rubyrick is offline
post #8 of 10 (permalink) Old 08-23-2008, 12:51 PM
San Diego Vulcan Rider
DeForestSD's Avatar
I got one from calmoto.com and found the threads didn't match so it's useless.
86' Vulcan, Stock & Lovin it!
Stator, R/R, splines lubed, ACCT's repl. at 25,200
Just turned 29,000 mi.
95' Vulcan, all stock, 9,700 mi.
John Spangler
DeForestSD is offline
post #9 of 10 (permalink) Old 08-23-2008, 01:56 PM
99vulcan750's Avatar
I have a 90 degree stem on my rear wheel.. $13from the stealer when they changed the tires for me... seems to me I got ripped off, haha
'99 VN750 with 8900 miles and growing (3,111 when I bought it 03-22-08)
Ear shave with Unipods
Drilled mufflers and degoat
TOC springs
N/C Street shield EX windshield
Jumbo Saddleman Highway Studded saddlebags
Willie and Max Saddlebag mounting kit
License plate turn signals
Home made sissy bar
Luggage Rack from Scoop
http://youtube.com/user/99vulcan750
99vulcan750 is offline
post #10 of 10 (permalink) Old 08-23-2008, 02:43 PM
That #1 looks good to me... That is the one I would go with, and if not it would be the one in the other post (low profile rubber) which looks to be +/-13/16-7/8", but they don't tie the measurements so you can't tell exactly how tall it is...
