air pressure and shock setting - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 08-13-2008, 10:45 PM Thread Starter
I am about 200 lbs anyone have an idea on shock and air pressure settings.Waiting for the manual and thought I would find out what you guys use,Thanks
dman is offline
post #2 of 14 (permalink) Old 08-13-2008, 11:26 PM
Shocks...20psi per shock...use a hand pump not a gas station air hose..
Tires, if stock, 32 rear and 29 front.
post #3 of 14 (permalink) Old 08-13-2008, 11:33 PM
Love My Baby
rubyrick's Avatar
You can also adjust the shock rebound on the top of the rear shocks. The 2 setting is the factory default, but with more weight on the seat, the 3 setting may be more appropriate. It dampens the rebound (bouncing) a bit. You're only 200 lbs, so it might not really matter. I'm 172 and I like the 2 setting. When I take my wife for a ride I set it to 3 because she doesn't like to bounce. It does seem to help.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #4 of 14 (permalink) Old 08-14-2008, 04:14 AM
750Doug's Avatar
I'm just a little over 200-I keep 15 psi in the shocks, and have the collars set on 3. That's what my back side seems to prefer.
750Doug is offline
post #5 of 14 (permalink) Old 08-14-2008, 06:30 PM Thread Starter
settings
Thanks guys good info
dman is offline
post #6 of 14 (permalink) Old 08-14-2008, 07:58 PM
haynes manuel says 0 to 43 psi. It does not specify either way per each or to add together. IMHO it would be per each one.
post #7 of 14 (permalink) Old 08-17-2008, 08:54 PM
robardin's Avatar
If I should be using a hand pump (as for a basketball) and not a compressor, what should I be using for the gauge? A tire pressure gauge is no good?
ETA: is this the sort of thing we're talking about? A "Topeak Mini-Master Pump w/Gauge" for $30 at the Sports Authority?
"Until you have the courage to lose sight of the shore, you will not know the terror of being forever lost at sea." (Despair.com)
robardin is offline
post #8 of 14 (permalink) Old 08-17-2008, 10:04 PM
Finallygot1's Avatar
I filled mine with nitrogen, figured if it was good for the tires it would be good for the shocks. PLUS that is what I fill the shocks on my sons 1/4 midget with
Brian
'03 VN750 7,754 as of 10/19
DE-goated,RE-goated,now DE-goated with H-pipe
Willie&Max Saddlebags
Mephis Shades Fats
NGK Iridiums
Cramp-buster throttle
Bulldog R/R relocate
'01 F150 Screw(for the bad weather)
Finallygot1 is offline
post #9 of 14 (permalink) Old 08-18-2008, 12:34 AM
ChrisC's Avatar
I use a bicycle shock pump. Bike Nashbar (www.nashbar.com) and Performance Bicycle (www.performancebike.com) have them for around $30 +/-. eBay has a whole bunch of shock pumps listed as well.
Chris
Wayne, NJ
1989 VN750-A5
VROC #27781
-MF Battery
-De-Goated/Re-goated
-Coastered
-Splines Lubed
-Stebel Nautilus Horn
-AutoMeter 2" VOM
-Silverstar Headlight
-Plexifairing III
ChrisC is offline
post #10 of 14 (permalink) Old 08-18-2008, 03:14 PM
robardin's Avatar
Eeep!
...or else what?
I happen to have used a small air compressor, meant for tires, when I first got the Vulcan. I just got the shock pump from a local bicycle shop at lunchtime today and will re-do the adjustment... But what irrevocable damage might I have done by using a compressor, how would I know, and what would I do about it?
robardin is offline
