Average Life of Stock Tires - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 21 (permalink) Old 08-12-2008, 01:58 PM Thread Starter
greenw's Avatar
I'm sure this has been asked and answered many times, but can someone tell me about how many miles can I expect from the brand new stock tires. I ride an average of 4000 miles a year, I am not hard on the bike at all. Just turned 8000 miles and the tires still look new.
Thanks for any advice
Wayne
2006 VN750
greenw is offline
post #2 of 21 (permalink) Old 08-12-2008, 02:27 PM
I have an 06 with 9000+ miles and the tread in the center of the back tire is almost gone. I think I was using a bit too much air.
I took a look at the front tire and found that the tread depth is fine but the edges are cupped.
So I'm replacing both tires with a bit less than 10000 miles. I ride my VN pretty aggressively, though, so you may get more life out of yours.
Mark
Mark is offline
post #3 of 21 (permalink) Old 08-12-2008, 02:45 PM
I was able to get 13000 out of mine.
2001 VN750
Vista Cruise Control
V-Force shield
Kawasaki Saddlebag supports
Fixed trunk hinge
TOC MCCT
Clear Alternatives LED tail light
Knifemaker style floorboards
Knifemaker style dash
Avon Venom X 110/90 Front
Avon Venom X 170/80 Rear
Big Crank AGM battery
25,100 miles as of 04/20/2010
lancer19 is offline
post #4 of 21 (permalink) Old 08-12-2008, 03:02 PM
11,000 miles. The rear tire probably could have gone a little bit longer, but I thought it best to replace both at the same time.
Harvey_birdman is offline
post #5 of 21 (permalink) Old 08-12-2008, 09:34 PM
scooterboy
My 06 has 9400 miles on it and the tires look good still.
Jim Sanner is offline
post #6 of 21 (permalink) Old 08-12-2008, 11:22 PM
dirtrack650's Avatar
I don't think I got more than 6k on my IRC's running near max pressure. I need to back off the throttle more ;-) and lose some weight.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #7 of 21 (permalink) Old 08-13-2008, 07:31 PM
HAWK
Ccspinner's Avatar
My Stock tires got only 10K, I put on Metlers and sold the bike with 23K and the tires still looked great.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #8 of 21 (permalink) Old 08-28-2008, 09:16 PM
ExNewbie..Still Learnin'!
rsawyer's Avatar
Sometimes time is more important than mileage. Rubber deteriorates over time and any tires coming up on the 5-6 year mark are getting pretty dangerous. If they're over 6 years, you're risking your life every time you ride. If you can see fine dry rot cracks then it's long overdue. Most experienced bikers I've spoken with have recommended every 3-4 years whether they're worn down or not. Same goes if you buy a "new-to-you" bike. Make sure you understand the date codes on the side of the tires. Look for a number starting with "DOT" and ending in either a three or four digit code (tires after the year 2000 have a four digit code) that indicates the week/year of manufacture. For example my front tire code ends in 3905 which translates into the 39th week of 2005. I plan to replace them next spring at roughly the 4-year point. Make sure to check any "new" tires you buy as there is a lot of "new" old outdated stock out there. If they're more than a year old, you're getting gipped and should complain/return/exchange them for a newer set.
'89 Vulcan 750
VROC# 30232
HID Headlamp Conversion
V&H Cruzers (great sound)
Kaw V-Force Windshield
Kaw Rear Luggage Rack
Kaw Engine Guard
VN750.COM Grill Cover
W&M Black Magic Saddlebags
Diehard M/F Battery
R/R Replaced/Relocated
Stator Replaced
Voltmeter Installed
Splines Lubed
Metzler 880 Marathons
Front - 110/90-19
Rear - 170/80-15
Carbs Balanced
Carb Mix Adjusted
Fuel Tank Derusted/Lined/Sealed
NGK Iridium Plugs
rsawyer is offline
post #9 of 21 (permalink) Old 08-29-2008, 07:03 PM
james brill's Avatar
For everyday commuting I was getting 12,000 on the rear and 18,000 on the front.
james brill is offline
post #10 of 21 (permalink) Old 09-02-2008, 10:53 AM
stan's Avatar
20K out of mine....
VROC #12293
2004 VN750
MSF Ridercoach
new tires (OEM Stones) 6/2008
home made floorboards (knifemakers styling)
stator replaced 6/2008
cobra slashcuts 7/2007
clear alternatives brake & tailight 8/2008
Added Mutazu hard bags 3/2009
added customLED load equalizers for the bags LED lights 3/2009
stan is offline
