Shock oil - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 08-06-2008, 09:06 AM Thread Starter
Scootergptx's Avatar
Shock oil
Got a little more dive in the front than I'd prefer. Don't think I need a total shock rebuild as it's not that old, or has that many miles. Has anyone gone to a heavier oil for theirs?
Scootergptx is offline
post #2 of 11 (permalink) Old 08-06-2008, 09:19 AM
Search Goddess
Dianna's Avatar
Not that I know of but many have gone to the Progressive Fork springs. Definitely worth the money for eliminating dive and improving handling
http://www.cruisercustomizing.com/de...irago_________
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #3 of 11 (permalink) Old 08-06-2008, 10:58 AM
Glenn M's Avatar
If you have an early 700/750, you just add some air to the forks.
Glenn
1985 VN700
Saddle Bags
Small Sport Windshield
R/R moved
Home built coasters
Kaw touring front fender
1990 Fuel tank
Kenda Kruz 110/90-19 & 170/80-15 tires
NGK Iridium plugs
NGK plug caps and 7mm copper core wires.
Deer Whistles
My VN700 pic's
VROC #7740
Glenn M is offline
post #4 of 11 (permalink) Old 08-06-2008, 12:22 PM
Like Glenn said, and I wish they had left the air on the later Mods.... But I went to progressives & 15W fork oil, seems to work pretty good for me...
post #5 of 11 (permalink) Old 08-06-2008, 01:44 PM Thread Starter
Thanks for the replies. Supposed to go out of town (in the truck ) so I may just drain them while I'm gone and refill it with the 15w.
Prolly save the progressive spring change for when I replace the front tire.
post #6 of 11 (permalink) Old 08-06-2008, 03:35 PM
750Doug's Avatar
In the Verses, there are a couple threads about fork oil, and changing it. Here's a point worth noting from one of those threads-
What I've found to work good in forks is 5W for riders up to about 140 lbs, 10W for riders 140-185 lbs, and 15W for riders over 185 lbs.
It's also suggested in there, as well as by some other members here, to use "Bel-Ray" fork oil when you change it.
750Doug is offline
post #7 of 11 (permalink) Old 08-06-2008, 08:27 PM Thread Starter
Thanks Doug. I guess seeing the rider weight with the oil weight would explain it.
post #8 of 11 (permalink) Old 08-06-2008, 09:55 PM
Heavier oil will not cure front end "dive"..only stiffer springs will.
I dissagree with the fork oil reccomendation, 15w Belray is the way to go if you are 130 lbs or 280. Heavier riders should just add a bit more preload to their Progressive springs.
So, if you do not have time to install new springs, but time to change the oil, you can at least add some preload to the stock springs by stacking up some washers or using something like some old sockets.
post #9 of 11 (permalink) Old 08-06-2008, 10:16 PM
Glenn M's Avatar
15w oil will slow the rate of dive, compared to 5w oil. It takes more energy to push the heaver oil through the orifices, than it does for the lighter oil. So in essence it adds to the spring rate.
Glenn
1985 VN700
Saddle Bags
R/R moved
Home built coasters
1990 Fuel tank
NGK Iridium plugs
Deer Whistles
My VN700 pic's
VROC #7740
Glenn M is offline
post #10 of 11 (permalink) Old 08-06-2008, 11:05 PM
In essence yes, but spring rate is figured by how much a spring compresses with X amount of weight on it. Time is not a consideration here. Weak springs and heavy oil are not the answer, just a lazy mans fix.
The Vulcans orifices are kind of large..so the effects of a heavier oil are less noticable than with some other bikes.
But yes, thicker oil will "slow down" the movement in most other cases.
