Anyone use Shinko Tires? Check out this 170-15 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 07-23-2008, 08:45 PM Thread Starter
dirtrack650's Avatar
I think I'm switching from IRC 150-15 to this Shinko 170-15
http://www.motorcycle-superstore.com...Rear-Tire.aspx
Also, anyone SNiPE their tires (slices in the tread to provide better grip)? Dirt trackers used to do it before trackmaster tires were on the market, and some tire shops in town will do it for extra $$$ when buying auto tires, but do any street bikers do it?
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #2 of 17 (permalink) Old 07-23-2008, 10:04 PM
DT
Most tires today are designed with state of the art computer programs that can factor in road type, rain, sand, etc...so tread patterns are pretty much the best one can hope for as they come from the factory...so cutting the tread and not knowing what you are doing or effecting is not really done anymore.
Keeping that in mind, the only complaint I have heard about the Shinko tire you have pictured is that wavy center groove they have seems to wear oddly and tends to follow rain grooves or edges in the road. The compond also seems not to like "road snakes" (those lines of tar they use to seal cracks)
Otherwise likely a good tire (for the money) Not however , heard anything good about their front tires, so I'd go with a Dunlop or Bridgestone there.
post #3 of 17 (permalink) Old 07-23-2008, 11:05 PM
So far, No complaints. I've got it on my front & rear. (different models but both shinko) I haven't put a bunch of miles on them yet But, HWSpeeds i'm happy with the "feel". Deffinetly a dollar for mile tire.
post #4 of 17 (permalink) Old 07-24-2008, 01:10 AM
Glenn M's Avatar
From what you say here, they pretty much suck.
Glenn
1985 VN700
Saddle Bags
Small Sport Windshield
R/R moved
Home built coasters
Kaw touring front fender
1990 Fuel tank
Kenda Kruz 110/90-19 & 170/80-15 tires
NGK Iridium plugs
NGK plug caps and 7mm copper core wires.
Deer Whistles
My VN700 pic's
VROC #7740
Glenn M is offline
post #5 of 17 (permalink) Old 07-24-2008, 01:53 AM
"Suck" may be a bit harsh, but sometimes you get what you pay for. For less than 90 bucks a tire, they are a alternative for those on a budget, and you have to examine the type of riding you do. If you are a full bore , sparks a-fly'n corner killer, they may not be the best choice, if you live in Kansass, where the sharpest curve is still pretty much a straight line , they may work out fine.
My take has always been that the only thing that makes your bike work as intended is the connection between it and the road. Higher priced tires have alot more technology in their make up and for the most part, how well they work in the rain, and how well they stick you to the pavement, and how many miles you can get out of them are always factors to consider.
One also tends to learn the limits of their tires and rides accordingly. I wish all tires exeeded my needs, but it always boils down to a comprimise between long life and good traction.
Many folks think they are already riding to the "limit" but are really only riding to the limit of their tires. The Vulcan is not a race bike, and not really able to "push the envelope" as a well fitted sport bike can, so there is some leaway as to what tires "work" with the bike.
post #6 of 17 (permalink) Old 07-24-2008, 09:49 AM
Glenn M's Avatar
Well, you're the one that described how bad the Shinko's handled curtain road conditions and how they wear. They sound just like my old Dunlops, which sucked.
As you stated, our bikes are not race bikes, but you want to feel safe and enjoy riding, not leery of every little crack, line, tar snake or bridge we come across.
I went with the lowest cost tire out there, the Kenda Kruz K673's. From what I've observed so far, they are more than a match for our bikes performance wise and they show none of the bad characteristics of the tires mentioned.
As for engineering and how well a tire is made. The Kenda's balanced out, with no wheel weights front or rear, that could not be said for the tires they replaced.
Glenn
1985 VN700
Saddle Bags
R/R moved
Home built coasters
1990 Fuel tank
NGK Iridium plugs
Deer Whistles
My VN700 pic's
VROC #7740
Glenn M is offline
post #7 of 17 (permalink) Old 07-24-2008, 10:12 AM Thread Starter
I checked out the Kenda brand too but my local shop doesn't import them. They will mount and balance the Shinko for $12 if I buy it from them.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #8 of 17 (permalink) Old 07-24-2008, 10:49 AM
Glenn M's Avatar
What do they charge to mount and balance a tire not bought from them? The reason I ask, the add you posted has the Shinko 170/80-15 is $90. The Kenda Kruz 170/80-15 is $60+ maybe $10 shipping.
I couldn't find anything about the Shinko, other than what was posted here.
I don't know, give the Shinko a try, it may or may not work for you. I and others who have tried the Kenda's know they work, work very well.
Glenn
1985 VN700
Saddle Bags
R/R moved
Home built coasters
1990 Fuel tank
NGK Iridium plugs
Deer Whistles
My VN700 pic's
VROC #7740
Glenn M is offline
post #9 of 17 (permalink) Old 07-24-2008, 01:32 PM
93VN750's Avatar
I had the Shinko Advance 005's (120F/200R) on my Meanie and got 10,000 miles out of them. They were good tires from a quality aspect, rode well, and handled well.
Went with Avon Storms now (130F/180R), wonderful tires.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #10 of 17 (permalink) Old 07-30-2008, 04:26 AM
170/90/15 it`s not to large for vulcan?
knauer is offline
