2001 Vulcan 750 Front Tire Removal - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 10-05-2015, 10:58 PM Thread Starter
Ryeloc's Avatar
So I'm getting a new front tire this weekend. They charge 99$ just to take the tire off the bike if I bring the whole bike, but only 25$ to put the tire on if I bring the front tire. So naturally I would like to save 75$.. lol
How hard is it to remove this front tire? What tools will I need?
Ryeloc is offline
post #2 of 12 (permalink) Old 10-06-2015, 12:27 AM
A jack to hold up the bike, 14mm socket for the brake calipers(not necessary if you can get the bike high enough) ,and I think but don't remember for sure but the axle is 19mm
post #3 of 12 (permalink) Old 10-06-2015, 01:27 AM
Didn't take my calipers off, but I think those bolts are 12mm or 10mm. Used a 2x6 block under the engine with a floor jack, along with having the bike on the center stand. It's a good idea to strap the center stand forward so it can't rock back and fold up.
Pay attention to the spacer location and how the speedometer drive is engaged in the hub and on the fork leg. Also have to loosen the axle clamp in order to pull the axle out.
Download the repair manual if you don't have one.
I used zip-ties to dismount/mount both my tires.
Last one was a front tire on a V-Rod, used no tire irons at all, just a larger c-clamp to break the bead on the old tire and wire cutters to cut the zip-ties off the new tire.
There's some youtube videos about it. Most of those have the wheel laying on it's side, but it seemed easier with the tire/wheel standing up and pulling the tire on by hand after seating it at the bottom. With a bare wheel and zip-tied tire, it took 15 seconds to pull the tire onto the wheel. Quicker than OJ putting on a bloody glove.
Kawi dealer quoted me $90 for 2 carry-in tire jobs. My cost, zero $ and about an hour. Spent a little cash using Ride-On to balance and puncture proof them. Yeah, my Kawi dealer is a nut.
post #4 of 12 (permalink) Old 10-06-2015, 01:36 AM
Was playing with the calipers on my cb750c today,so they may be 12.I play with too much **** and my brain lately works like a rock,so...
post #5 of 12 (permalink) Old 10-06-2015, 08:30 AM
JM2001's Avatar
$99.00 for an easy 10 minute job? What a rip off.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #6 of 12 (permalink) Old 10-06-2015, 09:38 AM
yup, call them stealerships for a reason
michiganteddybear is offline
post #7 of 12 (permalink) Old 10-07-2015, 03:01 PM
how much do they charge for a tuneup.?
or to just to adjust the valves?
greggj82 is offline
post #8 of 12 (permalink) Old 10-07-2015, 03:34 PM
you find one that charges for adjusting the valves on the vn750, run away, fast, dont walk...
they are hydraulic, and not adjustable
post #9 of 12 (permalink) Old 10-07-2015, 04:17 PM
Yep, and there can't be much in a tune-up other than changing plugs and cleaning/oiling the air filters.
post #10 of 12 (permalink) Old 10-07-2015, 04:46 PM
I've got a cheap rebuild kit for the rear shocks in the works.just need investors. $150 dollars mailed to...
