Brakes are soft - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 07-15-2008, 04:50 PM Thread Starter
Brakes are soft
Hello, I recently changed my brake fluid and pads and then bled the system. In fact I have bled the system 3 times with the constant pressure method - all 3 times for atleast 12 hours and yet after 2 days they seem to go soft on me. I have had no brake fluid on the ground therefore I am not convinced I have a leak. Anybody have an experience like this in the past?
vulcan77 is offline
post #2 of 11 (permalink) Old 07-15-2008, 05:18 PM
Kawika
davewex's Avatar
Make sure you are using DOT5 brake fluid...I think the manual recommends DOT4 or DOT5. I believe it has a higher temperature spec.
click here for more info
LETS RIDE!! VROC# 26137
☠ Black Candy ☠ '07 Mean Streak 1600
☠ Blue Crush ☠ '95 VN750-A11
davewex is offline
post #3 of 11 (permalink) Old 07-15-2008, 05:27 PM
Chucklehead
dragon159's Avatar
Are you losing any from the resevoir? If the level is going down that says there is a leak, I'd have to guess that the level is staying about the same which would indicate the master cylinder is bypassing. The other thought that just hit me, is there is trapped air in the master cylinder. Try leaving it overnight on the center stand with the cover off or at least loose, just be careful that you don't get water (aka rain) in there as it will ruin the fluid. Also check the gasket on the cover for rips/tears.
dragon159 is offline
post #4 of 11 (permalink) Old 07-15-2008, 06:08 PM
ChrisC's Avatar
You say all is well for a couple of days after you bleed the system? When they go soft, is there a change in the fluid level?
Chris
Wayne, NJ
1989 VN750-A5
VROC #27781
-MF Battery
-De-Goated/Re-goated
-Coastered
-Splines Lubed
-Stebel Nautilus Horn
-AutoMeter 2" VOM
-Silverstar Headlight
-Plexifairing III
ChrisC is offline
post #5 of 11 (permalink) Old 07-15-2008, 06:30 PM Thread Starter
The level has gone down slightly - it only seems to go down just after I bleed it. But again there is no fluid on the ground. I even wiped my hand around both calipers and it is dry. I have not tried leaving the master cylinder off - I will try that next but what does bypassing the master cylinder mean? I have used DOT 4 fluid.
vulcan77 is offline
post #6 of 11 (permalink) Old 07-15-2008, 06:47 PM
Chucklehead
dragon159's Avatar
Bypassing means the internal seals that push the fluid are not holding and the fluid leaks around them back into the resevoir. But the fact that the system holds pressure for a few days might say this is not happening. I'd try leaving the cover off overnight as the level has gone down, it's going somewhere... probably replacing super small air bubbles somewhere. Just a guess.
post #7 of 11 (permalink) Old 07-15-2008, 09:36 PM Thread Starter
I was thinking along the same lines, I will let you know what happens. Any other ideas please let me know. Thanks for the help so far.
vulcan77 is offline
post #8 of 11 (permalink) Old 07-16-2008, 12:39 AM
ChrisC's Avatar
Have you tried the "tap the lines with a screwdriver" trick?
Chris
Wayne, NJ
1989 VN750-A5
VROC #27781
-MF Battery
-Coastered
-Splines Lubed
-AutoMeter 2" VOM
-Plexifairing III
ChrisC is offline
post #9 of 11 (permalink) Old 07-16-2008, 12:00 PM
Sky Rider's Avatar
I had to tap the master cylinder with a screwdriver to dislodge the air in the pickup hole at the bottom. It took about 15 minutes of tapping and squeezing the brake handle to get it all out. You could see the bubbles coming out when you tapped it. Went through about 1/2 a can of brake fluid bleeding the stupid thing until I discovered the tap method.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #10 of 11 (permalink) Old 07-16-2008, 10:19 PM Thread Starter
Alright I bled it last night with the master cylinder cover off (although it was only for 8 hours) and this morning it was tight. After riding 100 miles today it seems to be going soft again. Still no leaks but I do hear a rubbing or rolling noise that sounds like it is coming from the left caliper when I use it - even after I apply and then let off. I don't know if this has anything to do with it but just something else I noticed. Is there something else I should be looking for possibly in the calipers themselves or in the master cylinder. The diaphragm appears to be in good shape.
vulcan77 is offline
