Speed Bleeder Bleeding - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 08-17-2015, 08:33 PM Thread Starter
Mike DeAngelo's Avatar
I came across this link while checking out Facebook.
http://www.speedbleeder.com/
you can bleed your own brakes easily or so they claim. They are $7.00 dollars each.
2008 Vulcan 900 Classic LT
HID lighting 35 Watt White
Chrome Slotted oval Mirrors
Chilhowee Tank Bra
Barons Big Air Kit
Vance & Hines Twin Slash staggered
EJK Gen 3 Electronic Jet Kit
1991 Vulcan 750 226 miles
Spiegler brake lines
rebuilt calipers, master brake cylinder
Mike DeAngelo is offline
post #2 of 5 (permalink) Old 08-17-2015, 09:09 PM
In theory, they should work as long as the tiny check-valve ball seals. It would be a good idea to have a hose on the end of the bleeder in a container of clean brake fluid with the hose below the surface, to prevent fluid and or air from going backwards if the check-valve fails.
'99 VN750, all stock
performed driveshaft maintenance
checked the ACCT using the Grambo Trick
Sycned carbs with flow meter
Yuasa YTX14AHL-BS AGM Battery
NGK DPR7EIX-9 Irridium Spark Plugs
vulcan1999 is offline
post #3 of 5 (permalink) Old 08-17-2015, 09:37 PM
I use a tiny bleeder kit that works on the same principle. Works well!
post #4 of 5 (permalink) Old 08-18-2015, 02:13 PM
cglennon's Avatar
I have SpeedBleeders on my VN750 and cars. Makes bleeding the brakes a snap (motorcycle or car). Just open the SpeedBleeders, pump the brakes, keep the brake fluid reservoir full and close the SpeedBleeders when you're done. Could not be easier and the only way to screw up is letting the brake fluid reservoir go dry. Easy to install too, just unscrew the old bleeder valve and screw in the SpeedBleeders.
The only downside to SpeedBleeders is you cannot reverse bleed (due to the one-way valve). However, you should never have to reverse bleed unless you let the brake fluid reservoir go dry or do major brake work (e.g., switch out the brake lines). For that, I would switch back to the old bleeder valves, reverse bleed and then reinstall the SpeedBleeders.
Chris Glennon - Portland, OR
cglennon is offline
post #5 of 5 (permalink) Old 08-19-2015, 12:53 PM Thread Starter
Maybe this should be part of the Vulcan verses since there are quite a bit of posts on brakes.
Chilhowee Tank Bra
Barons Big Air Kit
