NEW TIRES - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 07-15-2015, 10:36 AM Thread Starter
NYSGSP's Avatar
NEW TIRES
I just got my new Metzker 880s put on my Vulcan 750
What tire pressure works best with these tires
Thanks John
NYSGSP is offline
post #2 of 12 (permalink) Old 07-15-2015, 10:51 AM
The general consensus here has been 30 psi.
But I've found I'm wearing the center too quickly on the rear and am now trying 27psi. No difference in ride or handling, too early to tell about wear.
I'm running Shinko and they're oversized.
Pretty sure the sticker calls for about 29/29, close to that.
post #3 of 12 (permalink) Old 07-15-2015, 11:06 AM
I believe the Metzler site listed recommended tire pressure for those tires as 38psi front, and 42psi rear.....
If I can find the thread on this I will post it up....
Edit....only found their guide. The figures I gave were from past members...Metzlers own chart lists for the VN750 36 front, 40 rear:
http://www.cruisercustomizing.com/gr...ment_chart.pdf
Keep in mind their listing is for "minimum tire pressure" , so that 38/42 might be the way to go if you are heavy or riding two up.
Edit 2....found one of the more entertaining threads on this:
https://www.vn750.com/forum/showthread.php?t=20691
post #4 of 12 (permalink) Old 07-15-2015, 12:14 PM
Headbanger/Popes of Hell
ruger's Avatar
I'd have to go with KM on this one.
ruger is online now
post #5 of 12 (permalink) Old 07-22-2015, 11:21 AM
I'm going to openly admit my ignorance (stupidity?) up front.
When I got my new tires (Metzler 880) it didn't occur to me that the pressure would be different that what the VN750 manual suggests. I've been keeping them at the pressures stated on the sticker on the bike.
Time to up them to 38/42 I guess.
glad this thread was posted.
Old Bike: 2006 VN750 - Sold
eusjma is offline
post #6 of 12 (permalink) Old 07-22-2015, 02:55 PM
Not stupid...just uninformed... Am sure you're not alone.
But it is wise when buying any tire to check with the tire maker and see if they have a recommendation on pressure for your particular model. Not all makers list this of course, many, like Shinko, seem deliberately vague...
I doubt you did any damage by running that lower pressure, you may have accelerated wear, but it's not like these bikes eat tires. It's not uncommon for sportbikes to go through a tire in under 5,000 miles. Most cruisers are fairly kind on tires...and on tire pressures.
Heat is the biggest issue, and most tire pressure recommendations are based on finding a tire pressure that nets the lowest rise in tire tempature. You can get one of those laser tempature readers and do your own testing to find out the optimum pressure for your own tires too....
post #7 of 12 (permalink) Old 07-23-2015, 12:40 AM
pmassey31545's Avatar
But how the heck am I supposed to measure tire temps while traveling at 65mph
Hahahahaha
DISCLAIMER: This post is meant to be sarcastic and is in no way to be used as instructions or as a means to measure actual tire temperatures. The correct method would be to drive the motorcycle and come to a complete stop. Rest the cycle on the kickstand/center stand. Dismount and then measure tire temperatures.
2005 Vulcan 1500 Classic FI
Previous bike: 2002 Vulcan 750
pmassey31545 is offline
post #8 of 12 (permalink) Old 07-23-2015, 12:54 AM
you need to get on 341 when the traffic is not there and get your wife to point a laser temp gun at your tires as she rides along beside you. Viola you temp
Grace and Peace to you!
Richard
mrseedsower is offline
post #9 of 12 (permalink) Old 07-23-2015, 10:43 AM
Wrong....you have to stop the bike and take a reading at the center of the tire. You won't get a proper reading if the the bike is moving as its surface is being cooled by the moving air.
Yes, I realize you were joking ...but there are folks stupid enough to try pointing the laser thermometer at their tire while riding....
post #10 of 12 (permalink) Old 07-23-2015, 11:15 PM
Ummmmm.......no!
Good point. Now you got me thinking I should delete that post in the interest of safety. I'll just put a disclaimer.
