please suggest next steps in front brake issue. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 05-27-2015, 10:54 PM Thread Starter
Competent Noob
OK I am getting frustrated. What happens is after a short ride, the front brake locks. I have changed the fluid and bled everything. I know the fluid flows freely from the ms to both calipers. I have taken the calipers apart and cleaned them. The one on the left will compress in with light clamp pressure. The one on the right will not compress in no matter how much clamp pressure I apply. I believe this causes the pad to rub, create heat, and push the piston out further, locking the brake tight. Why can't I get the fluid to push back out of the caliper on the right side but I can on the left? I took the entire right side apart and everything is clean. Oh, by the way, when I loosen the bolt for the line, it still will not compress. When I loosen the bleeder valve, it will compress.
1995 Vulcan 750
Purchased 5/3/2015 w 10,600 miles
No mods I'm aware of
DieselPlower is offline
post #2 of 6 (permalink) Old 05-27-2015, 11:06 PM
JM2001's Avatar
Did you check the fluid seal around the piston? A defective seal can cause your problems.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 6 (permalink) Old 05-27-2015, 11:51 PM
what do the shafts that the outer pad rides on look like? If they aren't shiny they may be wedging. That is what mind did. I took them off and took 120 grit emory cloth and sanded the rods or shaft until they shined. Then I took 150 grit sandpaper until there were smooth. I went to Advance Auto Parts and got some high temp brake grease that is really sticky and put it on the bike. The first time I pushed the bike I almost dropped it as there was no resistance on moving the bike.
Grace and Peace to you!
Richard
mrseedsower is offline
post #4 of 6 (permalink) Old 05-28-2015, 12:10 AM
Sounds like the line to that caliper is clogged up
post #5 of 6 (permalink) Old 05-28-2015, 11:26 PM Thread Starter
Competent Noob
Well, it seems the tiny return hole in the master cylinder was clogged. I thought I had it cleaned out but I guess I didn't. Seems to be working fine now. Thanks for all the help.
1995 Vulcan 750
post #6 of 6 (permalink) Old 05-29-2015, 04:10 AM
Third instance of this this season I've read about on here. Good to keep an eye out for.
