how can I get brake fluid back into the lines? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 05-13-2015, 08:24 PM Thread Starter
Competent Noob
OK I messed up. I emptied thefront brake lines and now I cant get fluid back into them. Any suggestions? The fluid was filthy and thre were solids in the master cylinder. I have everything clean.
1995 Vulcan 750
Purchased 5/3/2015 w 10,600 miles
No mods I'm aware of
DieselPlower is offline
post #2 of 10 (permalink) Old 05-13-2015, 08:40 PM
JM2001's Avatar
Originally Posted by DieselPlower View Post
OK I messed up. I emptied thefront brake lines and now I can get fluid back into them. Any suggestions? The fluid was filthy and thre were solids in the master cylinder. I have everything clean.
I used to bleed them the old manual way. Now I have SpeedBleeders.
http://www.speedbleeder.com/feature.htm
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 10 (permalink) Old 05-13-2015, 08:54 PM
these brakes are notoriously hard to get bled too. speed bleeders help, but you may still have a soft lever (many, including me have). it just takes time, time, patience, and more time and patience sometimes to get them up to par again.
of course, make certain you do NOT let the master cylinder go dry during the process. it don't hold much and don't take long to empty
michiganteddybear is offline
post #4 of 10 (permalink) Old 05-13-2015, 09:12 PM
Mike DeAngelo's Avatar
I used this a couple weeks ago and it worked. No problems.
http://www.harborfreight.com/brake-b...kit-69328.html
2008 Vulcan 900 Classic LT
HID lighting 35 Watt White
Chrome Slotted oval Mirrors
Chilhowee Tank Bra
Barons Big Air Kit
Vance & Hines Twin Slash staggered
EJK Gen 3 Electronic Jet Kit
1991 Vulcan 750 226 miles
Spiegler brake lines
rebuilt calipers, master brake cylinder
Mike DeAngelo is offline
post #5 of 10 (permalink) Old 05-13-2015, 09:15 PM Thread Starter
Competent Noob
The fluid won't go from the master cylinder into the lines.
1995 Vulcan 750
post #6 of 10 (permalink) Old 05-13-2015, 09:33 PM
It's likely clogged. There is a tiny hole the fluid goes through to get into the lines, you'll likely need to clean it out by hand.
post #7 of 10 (permalink) Old 05-13-2015, 10:20 PM Thread Starter
Competent Noob
Holy crap I got it! Thanks everyone.
1995 Vulcan 750
post #8 of 10 (permalink) Old 05-14-2015, 02:28 PM
For some reason, everytime I do brakes I think it's clogged and then after forever, it starts suckin some up.
post #9 of 10 (permalink) Old 05-14-2015, 02:37 PM
Put a hose on the blender valve,open blender,then suck on the hose.just stop sucking before the brake fluid gets to the end of the hose cause brake fluid tastes like ****.don't ask how I know.
post #10 of 10 (permalink) Old 05-14-2015, 03:51 PM Thread Starter
Competent Noob
Strangest thing. I could not get it to take any fluid. I am a motorcycle noob but I know what I am doing. I also had help from my buddy who is pretty good on motorcycles. He had to leave but I kept at it. I was trying many different things. What finally worked was I pulled the lever, put a locking vice grips type of pliers on the hydro line, and then let go of the lever and it started sucking. Strange. I had to repeat that process a few times and then it worked normally.
1995 Vulcan 750
