Tire info - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 15 (permalink) Old 05-07-2015, 11:05 PM
JM2001's Avatar
Originally Posted by heaney750 View Post
the vn750 was made to hold a 250 lb rider plus an extra 300 lbs of accessories so if the two of u together r more than 550 lbs then u shouldnt do it i ride my son all the time im 200 lbs and so is he and i dont have any problems
I have to disagree in the interest of safety. There is no way a VN750 can carry that weight SAFELY. The GVWR is 918 pounds. The wet weight is around 530 pounds. Accessories and equipment around 20 pounds, clothing about 20 pounds, plus 400 pounds rider and passenger. That puts you at 970 pounds, 52 pounds over GVWR. You have no safety margin. Yes the bike can carry the weight but it is not safe. JMHO
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #12 of 15 (permalink) Old 05-10-2015, 10:01 PM
Everything you wanted to know about motorcycle tires but were afraid to ask:
http://www.mic.org/downloads/mic_tire_guide_2012v1.pdf
Thought this thread should be "stickied" KM, so I did it.
post #13 of 15 (permalink) Old 01-03-2016, 06:15 PM
You are right JM2001. I can't find my Clymer manual right now, but IIRC the VN750 dry weight is 487 lb, and coolant, oil and gas adds another 30-40 lb. I DO REMEMBER that the maximum additional weight allowed was 397 lb. That includes any chromed parts such as engine guard, luggage rack, highway pegs plus windshield, saddlebags, extra running lights etc. Then you add the rider, passenger and their riding gear. Two lightweights might be comfortable on the back of a VN750, but I have got to say heaney, that two 200 lb riders puts you right at the upper limit of recommended GVW, without any additional gear or accessories.
post #14 of 15 (permalink) Old 08-10-2019, 03:00 PM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
Old thread but, info is info. I wish that I had thought about pre-weighing all of my additions to the bike before installing them. There is NO way I'm about to take it all off so I can satiate my curiosity about the cumulative weight penalty I've added.
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
National Cycles Low Boy Heavy Duty windshield
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Progressive 412 shocks
Chris and Shim is offline
post #15 of 15 (permalink) Old 08-10-2019, 07:41 PM Thread Starter
And then you see photos of guys in Asia hauling crates of heavy produce on tiny cc motorcycles and scooters, and have been doing it for years.
And I've seen folks with heavily loaded small bikes touring the world on them.
I think if you and your wife weigh over 250 each my first question is how comfortable can you be given the limited seating arrangement on the Vulcan?
