Front brake rebuild question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-01-2015, 09:22 PM Thread Starter
Mike DeAngelo's Avatar
I've cleaned up the brake calipers and pistons. I have a couple questions I'm hoping someone here can help me. Do the boots 49006 and 49006a have grease in them. It seems the 43044HOLDER-COMP-CALIPER had grease on it. What type of grease? Also I put them in is the 43049RING,PISTON SEAL higher on one side? I'll find out when i put it in I just thought I would get a heads up. If you have any cheats or advice I'd appreciate it.
2008 Vulcan 900 Classic LT
HID lighting 35 Watt White
Chrome Slotted oval Mirrors
Chilhowee Tank Bra
Barons Big Air Kit
Vance & Hines Twin Slash staggered
EJK Gen 3 Electronic Jet Kit
1991 Vulcan 750 226 miles
Spiegler brake lines
rebuilt calipers, master brake cylinder
Mike DeAngelo is offline
post #2 of 4 (permalink) Old 04-02-2015, 12:15 PM
The manual says: "Apply a thin coat of silicone grease to the caliper holder shafts and holder holes. (silicone grease is a special high temperature, water-resistant grease)"
So greasing the shaft would end up with grease on the boots, but you don't need to grease the boots themselves. A light coat, so it doesn't squish out/and or collect dirt.
Isn't there a groove in the piston for this seal to fit into? If so, it should be the same all around the piston. I may not understand the question.
post #3 of 4 (permalink) Old 04-02-2015, 09:47 PM Thread Starter
Yes there's a groove. I was watching a caliper rebuild vid and I saw the ring seal that fits in the groove is higher on one side (inside or outside not sure). Thanks for the info from the manual. I need to get one of those soon. Thanks for all your help!
Chilhowee Tank Bra
Barons Big Air Kit
post #4 of 4 (permalink) Old 04-02-2015, 10:13 PM
I should look at the video, kinda unsure about the ring sitting higher. The piston I looked at appeared to just have a straight groove around it. Could the ring have not been fully seated yet?
Get the download manual here on the site if you're on a pc and not a phone. Freebie!
