Reattach kickstand spring? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 03-28-2015, 11:04 AM Thread Starter
Any trick to this? I took it off a few months back to repaint the frame and I'm trying to find a decent way to attach it - can't get it anywhere near where it needs to be. Center stand was easy, it folds back all the way up to where the spring just about fits.
'92 Kawasaki Vulcan 750
Mods:
Rattle-can high gloss black paint job
Frame, engine, Headers/exhaust painted satin black
Ears shaved, K&N pod filters
TPE Stator, MOSFET R/R, Magna Power AGM battery
Pickup Coil mod
New mirrors, grips, cables
VN900 seat
Straight pipes with 8" baffles
kagaku is offline
post #2 of 6 (permalink) Old 03-28-2015, 11:17 AM
heaney750's Avatar
bolt the kickstand in place put the spring in the frame and use a pair of vice grips to pull the spring to the kickstand
heaney750 is offline
post #3 of 6 (permalink) Old 03-28-2015, 11:19 AM
1) use a length of tie wire or cord to pull the spring
2) screwdriver through the spring hook and the tip placed on the spring post, lever the spring to the post
3) vise-grips on the spring, pull the spring to the post or hole
Extra hand sometimes makes all the difference. Beware of the flying spring!
post #4 of 6 (permalink) Old 03-28-2015, 12:02 PM
cglennon's Avatar
I removed my side stand over the winter to clean and grease it. Here is how I removed and replace the spring.
  1. Extend the side stand to the full open position.
  2. Insert coins, quarters worked best, into the openings in the now fully extended spring. As many as you can force into the opens. Double them up if possible.
  3. Retract the side stand.
  4. The coins keep the spring extended and the spring will fall off before the side stand is fully retracted.
  5. Reverse to install.
  6. Slowly extend the side stand while holding the spring with coin extension setup in place.
  7. Continue fully extending the side stand and the spring will fall into place.
  8. Remove the coins.
  9. Done.
You can do the same thing with the spring removed.
  1. Bend the spring into a U shape.
  2. Insert coins in the large openings at the base of the U.
  3. Flip the spring over.
  4. Bend the spring into U share.
  5. Insert coins.
  6. Repeat until you can't insert any more coins. Use a pair of needle nose pliers to really stuff them in as much as possible.
  7. Install as outlined above.
Chris Glennon - Portland, OR
cglennon is offline
post #5 of 6 (permalink) Old 03-28-2015, 12:30 PM
You need one of these:
You can make your own from an old T handled Allen by just heating the tip and bending it into a hook...remember to reheat and quench in cold water to reharden it.
post #6 of 6 (permalink) Old 03-28-2015, 03:50 PM Thread Starter
I managed to get it back on using the coin trick and two pairs of vice grips to handle it. Thanks all!
kagaku is offline
