NEW TIRE's UPDATE - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 05-10-2008, 04:13 PM Thread Starter
2001Vulcan's Avatar
NEW TIRE's UPDATE
Ok here is what happened, I put on a 170/80-15 rear and a 110/90-19 front. Both were pierelli MT66. I personally did not care for the way the bike handled with the bigger rear tire, just felt sluggish and not as quick or nimble,(I drive more city and twisties then anything else) Also only saw rpms go down only about 100-150.
So I put on a 150/90-15 MT66 and the bike FEELS so much better, quicker,easier turning into corners, feels stable, lower speed handling ,etc...
I'm not sure what to say about it, I REALLY like the bigger 110 up front, but I did not like the 170 on the rear. I prefer the 150. Just my humble opionion and experience over the last 10 days and 400 miles.
2001Vulcan is offline
post #2 of 6 (permalink) Old 05-10-2008, 09:14 PM
OEM has this all figuered out in their high tech tests, dont mess with the tires or sizes, they put all that stuff through hell to make us as safe as possible and so does the tire manufacturer, they work together on that closely, very closely.
Ride steady now!
Mastertech is offline
post #3 of 6 (permalink) Old 06-05-2008, 11:15 PM Thread Starter
2001Vulcan's Avatar
1000 mile update
well I have now put 1100 miles on the new route 66 tires.. They handle well on the twisties, and on uneven road surfaces. not too bad in the rain. I have noticed they need to be kept at 29 ft and 33 rear, that's where they feel the best. decent mileage , I avg. 42 mpg. also speedo is 4200 @ 60 5000 @ 70
post #4 of 6 (permalink) Old 06-06-2008, 12:01 AM
85 VN 700
curtis97322's Avatar
The issue with that theory is that these bikes were designed over 20 years ago. A LOT has changed in those years....
Ride steady now!
Curtis - Albany Oregon.
Ammo Can Saddlebags
Hit the 24k mile July 2008
curtis97322 is offline
post #5 of 6 (permalink) Old 06-06-2008, 12:37 AM
Sky Rider's Avatar
But tire size and handling characteristics haven't changed all that much for this bike. Tire make up and the rubber chemistry HAS changed but from a handling perspective, the tire sizes should still be kept as close to spec as possible. That being said, I don't think going to the larger front tire has as much of an impact since it is about the same width as the original. The wider 180 would put more rubber on the road but the side wall stiffness would be greater causing the sluggish handling 2001 talks about.
Just my .02
Jim W
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #6 of 6 (permalink) Old 06-06-2008, 01:50 AM
dirtrack650's Avatar
Confirmed
This is exactly what my local shop said would happen when I asked about increasing the tire size.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
