how do you adjust/check air shocks? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 03-14-2015, 02:41 PM Thread Starter
rear shock air pressure
Does anyone know what the air pressure is supposed to be? My 750 is bottoming out a little
clawwd is offline
post #2 of 12 (permalink) Old 03-14-2015, 03:48 PM
Headbanger/Popes of Hell
ruger's Avatar
it's not very much. I can't remember what it is right of the top of my head. but I do know it's not much at all.
how many miles on your bike? are those original shocks? if so, they maybe just plan wore out. or maybe you just need to go on a diet. sorry about that, I just couldn't help myself. just too easy. I'm only joking about the diet.
I'm sure someone will be along really soon with the right #'s. just a thought, did you adjust the shock manually? these shocks have both air and manual adjustments on them. it's nice to have options. I like options.
ruger is online now
post #3 of 12 (permalink) Old 03-14-2015, 05:38 PM
2000 VN 750 Senior Member
The pressure should be 10% of the load you are putting onto the bike. That would be your weight and any additional things you add but this is the formula for when the shocks are in good condition. Over time the seals may have dried and/rotted away etc. I have been told to add air only through a hand pump to avoid over filling and causing a problem. Also the springs that assist the shocks may be weakened.
Do a search here on the forum of the topic and you will find a vast amount of information on that particular subject. Also looking we are looking for your introduction post under the Newbie Check-In heading where you can tell us a bit about your riding/wrenching experience and your location. That is always helpful when you are needing some assistance as it helps regular forum members know what kind of advice to give you. If someone knows you are just starting out then they wouldn't be telling you to tear the entire motor apart. Also knowing where you are located lets others possibly offer hands on assistance if needed.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #4 of 12 (permalink) Old 03-14-2015, 05:49 PM
ruger's Avatar
this might help......
https://www.vn750.com/forum/showthread.php?t=6409
ruger is online now
post #5 of 12 (permalink) Old 03-15-2015, 12:45 AM
Chuck A.'s Avatar
Less I was totally packed for a trip I put the shocks on #4 setting and used 20 pounds of pressure. I'm a large country boy and that did good for me. I ride the ruff backroads a lot. Any more air than that just jacked the bike up.
Chuck A. is offline
post #6 of 12 (permalink) Old 03-15-2015, 05:39 PM
Originally Posted by ruger View Post
Thank you, Ruger. I remembered reading through that thread some time back but did not get a chance to search for it myself.
Tom
Vulcan 2000
4507 miles
post #7 of 12 (permalink) Old 03-15-2015, 06:49 PM
Like it say I'm a new owner it's a 92 750 and don't know to check or adjust the air shocks could use a little knowledge on the shock systems so I don't f anything up..
Joes92vn750 is offline
post #8 of 12 (permalink) Old 03-15-2015, 07:03 PM
Get the download manual from Kanuck's signature, section 12-10 says 0-43psi, depending on weight load and road conditions.
Front forks use a lot less on the max. pressure, but can also run zero. later models don't have the air forks.
You need to use a hand pump and not a compressor, too easy to blow the seals out.
Damping adjustment 1-4 is, 1- bouncy, 4-firm.
post #9 of 12 (permalink) Old 03-15-2015, 07:09 PM
Manual shows 0-43psi for the rear. Air front forks (early models) only go to something like 7psi.
The soft damper setting for the rear, 1, would let mine bottom out on certain bumps, but 4 got to be too firm, I settled on 3.
post #10 of 12 (permalink) Old 03-15-2015, 08:33 PM
rsavant's Avatar
Aren't the shocks filled with nitrogen from the factory or am I mistaken?
"Katie"
2002 VN 750, stock except for accessories
Mustang seat
Super Bright LED brake strobe on trunk
About 25k miles
All drive train maintenance performed, drive shaft coupler replaced
Way more experienced at pulling VN 750 carbs than I ever wanted to be.
TOC ACCT rebuild kits installed
Pick up coil mod
Cooling system flushed, refilled with fresh coolant
Petcock rebuilt
VN sold, current steed Honda ST 1300
rsavant is offline
