FORK & KONIS - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 12-05-2014, 07:25 PM Thread Starter
FORK & KONIS
I'm well into Winter tasks. Silverwing had general service & fork seals. VN got seals & springs. I happened to have some springs(don't remember from what)that seemed good for it-same OD & wire size,progressive wound,+1.25" in length. On top of that I had a set of Konis sitting on my GT380 that were too stiff for it-upon searching Ikon's site I found they were for the Guzzi Le Mans III&IV. Hmmm-shaftie about the same weight as VN should work good. They are 12mm longer so may lift rear a bit & with the forks up 30mm the steering may be close to the quickness I'm looking for. Put a new front tire on so maybe the only thing left is doing something w reversed shift pattern. Does anyone know if the internal link can be flipped 180 to preclude adding an external link w shifter pivoting by foot rest. I have a conventional lever mounted backwards giving racer style pattern like my Guzzi had. I can live with it but in my confusing "Golden Years" jumping from bike to bike might become a problem. Thanks,GJ
guzzi john is offline
post #2 of 10 (permalink) Old 12-05-2014, 10:43 PM
What?
post #3 of 10 (permalink) Old 12-05-2014, 10:55 PM
He's got the shifter on backwards so it's 1 up 4 down.remember he made mids.
post #4 of 10 (permalink) Old 12-06-2014, 12:43 PM Thread Starter
NOPIX??!!
I've surfed looking for a photo of the linkage w side cover off but haven't found one. Just wondering if there is room to allow the link to work diagonally.
post #5 of 10 (permalink) Old 12-07-2014, 01:43 AM
Here is a link to Bike Bandits parts diagrams. You will have to click on "transmission" in the left sidebar, then "OEM parts", then "change mechanism"
http://www.bikebandit.com/oem-parts/...hine1#sch46655
Hope this helps, but I do not think you can do what you have described.
post #6 of 10 (permalink) Old 12-07-2014, 11:46 AM Thread Starter
Yup
Thanks,but I'm well acquainted w parts diagrams. I was hoping to find a shot of the mechanism w the cover off. I wish there had been a version of this engine w the shift shaft coming straight out through the side cover. I'll just have to pull the cover and see. The alternative would be to change the patterns on my XV500 & Futura to match but the GL650 doesn't have the external linkage so it is stuck w the conventional pattern. It would take a lot of "Rube Goldberg" to change that one.
post #7 of 10 (permalink) Old 12-07-2014, 06:07 PM
The shift shaft runs across the motor to the right side. Seeing the cover off the left side wouldn't give you much information.....
I'm still not sure here what you're asking or want to do ...
post #8 of 10 (permalink) Old 12-07-2014, 06:45 PM Thread Starter
not so maybe
I tried to add a PS to last entry but it didn't work. Much eloquent BS was lost but I found the answer on Clymer pg186 showing the oil pump right above the linkage making my idea impossible.
post #9 of 10 (permalink) Old 01-03-2015, 09:10 PM
i have the right side off mine if it helps
ken4413 is offline
post #10 of 10 (permalink) Old 01-03-2015, 09:11 PM
i can run out and take a close up. sorry was not thinkin right. what you need to see is inside the inner cases
ken4413 is offline
