front brake drags... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 03-25-2008, 09:39 AM Thread Starter
99vulcan750's Avatar
On my recently acquired 1999 vulcan 750, the front brake drags slightly.. making it really hard to push/move. I don't have a repair manual and I would like to get this problem fixed before riding season.. what's the best way?
Thanks!
99vulcan750 is offline
post #2 of 11 (permalink) Old 03-25-2008, 10:14 AM
Undercover Sportbiker
AJCruzin's Avatar
Some drag is normal. If you suspect that it is excessive, pull hte offending caliper, clean all the parts, and give it a thorough inspection and lubing where appropriate. You could also check to see if the rotor is warped without taking anything off. Put the bike on the center stand and prop the front wheel off the ground. Standing directly above the wheel, spin it slowly (but not TOO slowly) while looking straight down at the rotor. Any warping will be immediately apparent. Also, if the pads drag more at certain points than others, you will be able to hear the change in tone.
AJCruzin is offline
post #3 of 11 (permalink) Old 03-25-2008, 04:11 PM
Crobins365's Avatar
You may want to check your rear brake, too - not saying that your front ones aren't dragging some, but as AJ said, some drag is normal. On the center stand, you can spin the rear wheel - as long as you're in neutral, it should turn pretty freely. The adjusting barrel is on that cable that comes across the frame and hooks into your "pad safety level" lever (say that three times fast!). Turning the barrel CCW puts more slack in the cable (if you're dragging, that's what you want); CW tightens it (if you undrag it too much and need to cinch it down a little).
The only reason I say also check the back is ...experience.
C
Crobins365 is offline
post #4 of 11 (permalink) Old 03-25-2008, 05:06 PM Thread Starter
the rear is good.. its just the front that I have to straddle the seat, and yank back to get the bike to roll... or shift my weight forward real hard to get it to go forward..
post #5 of 11 (permalink) Old 03-25-2008, 05:23 PM
Senior Lurker
Sloppyburpfest's Avatar
A badly dragging front brake can be very bad for your health. Dragging brakes cause heat -> heat transfers to the brake fluid -> boiled brake fluid = loss of the ability to brake!
Your brake calipers need to be pulled apart and cleaned ASAP. You may even need new brake seals. It's cheap life insurance, fix this soon.
My Flickr Gallery < Link >
Küryakyn LED battery monitor
R.I.P. Lance328
Sloppyburpfest is offline
post #6 of 11 (permalink) Old 03-25-2008, 05:29 PM Thread Starter
yep.. well, the 5-6 inches of fresh snow say I have a few days.. or weeks, lol.. never know up here in the MI UP lol.. thanks.
post #7 of 11 (permalink) Old 03-25-2008, 10:42 PM
Sky Rider's Avatar
That and do yourself a favor and get a shop manual. The Kaw manual is OK as is the Clymer's. The Kaw manual is a free download from TOC but is a large file if you're on dial up. The $20 or so you'll spend on a paper manual is well worth it if you are going to do any type of wrenching on the bike. The anwers to most questions are contained in them and you won't have to wait for a timely response on a Saturday when we are all out riding.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #8 of 11 (permalink) Old 03-25-2008, 10:59 PM Thread Starter
where is the TOC?
post #9 of 11 (permalink) Old 03-26-2008, 07:00 AM
Crobins365's Avatar
Originally Posted by 99vulcan750 View Post
where is the TOC?
http://www.tocmanufacturing.com/
You can find it under "Other Links."
I have all three manuals (shop, Clymer's and Haynes) - each is a little different in terms of explanations, ability to actually view and interpret their photographs, etc. Well worth the money - doing the work yourself will save you a ton in shop labor charges.
C
post #10 of 11 (permalink) Old 03-26-2008, 03:46 PM
dirtrack650's Avatar
Air in the brake line will cause brake drag. My front wheel moves freely with little drag.
Short story here: I was riding home from work on my GL500 and noticed a loss of power - or so it seemed -. I pulled over and smelled hot. Looking down at the front wheel my disk was red - in daylight! The problem was traced to a leaky O ring on the caliper. Replaced the O ring, changed the fluid, bled the system and it's been fine for years.
BTW - to get home I loosened the bleeder valve to relieve pressure. Try that on your VN to free up the front brakes. You will need to bleed after this test.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
