fork oil? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 03-08-2008, 08:44 AM Thread Starter
fork oil?
Hi all.
just got progressive fork springs and I am wondering what is the best weight fork oil for replacement with these springs and any brand better than others?
also how much oil needed for each fork?
thanks, John
free wheel-e is offline
post #2 of 4 (permalink) Old 03-08-2008, 10:17 AM
93VN750's Avatar
Fork oil is sold in three different weights depending on the load expected.
I don't know how/if the progressive springs make any difference in the equation.
5W provides least dampening while 20W provides the most. I weigh 230, almost always ride solo and put 10W in mine and am happy with that.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 4 (permalink) Old 03-08-2008, 10:23 AM
Most folks that did the change used 15W Bel-Ray.
post #4 of 4 (permalink) Old 03-08-2008, 11:45 AM
Growling at the World...
bulldog485's Avatar
Send a message via Yahoo to bulldog485
Here is a page that I put together on replacing the fork seals on a VN750.
http://www.bulldogsbike.com/forkseals.htm
I would recommend that you at least look at it as it might provide some guidance in your spring replacement. Keep in mind that you will need to either cut the spacer in the tube or make a new one if you don't want to cut the ones you have. PVC works for a new spacer quite well. I don't remember the exact length, but something tells me that 7-1/4" is about right.
I have Progressive springs and I use whatever the Kaw shop recommended. You might want to examine your seals and decide if you want to replace them while you are taking the front end of the bike apart. It would save you some time later down the road.
Evan Breyn ~ The Bulldog
2006 Harley Davidson Ultra Classic FLHTCUI ~ The Big Black Bitch ~ 26,000 miles.
2002 Kawasaki Nomad 1500 ~ The Red Dog ~ Traded in at 22,000 miles of smiles (purchased new 10/05 / Traded in 6/12).
1990 Kawasaki Vulcan 750 ~ Black Betty ~ 34,999.7 miles
VROC ~v~ 485
McHenry County Road Pirates
Chicagoland, IL
bulldog485 is offline
