Switch Spring - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 04-04-2005, 03:22 PM Thread Starter
Switch Spring
Through the process of tearing apart and rebuilding my bike, I've ran across a "switch spring" that is attached to the rear brake pedal. When the break pedal is pressed down the spring pulls down the rear brake light switch tabs which inturn makes the rear brake light turn on.
I've looked at the parts diagram and can not find this spring. I can only find the return spring listed.
Any help?
I've actually found the return spring, or one that fits perfect at Lowe's but have been unable to locate a switch spring.
Thanks
Jason
Ritthjp is offline
post #2 of 3 (permalink) Old 04-05-2005, 12:29 PM
Re: Switch Spring
The spring on the switch for the back break is 92081-1544. It is under Ignition Switch / Locks / Reflectors.
dmauray is offline
post #3 of 3 (permalink) Old 04-06-2005, 09:58 AM Thread Starter
Re: Switch Spring
Thanks!
Ritthjp is offline
