Broken front right footpeg - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 09-16-2014, 10:25 PM Thread Starter
Proud Owner of '99 VN 750
furikazashi's Avatar
I wasn't sure where to put this thread but that being said my front right footpeg broke clean off. Ive ordered a new one that comes onto the black mount since they're not supposed to be separable. It comes in tomorrow but behind it looks complicated to install. Anyone here have advise?
ID:	18969   Click image for larger version
furikazashi is offline
post #2 of 6 (permalink) Old 09-16-2014, 10:28 PM Thread Starter
See how it looks like it seems to slide on from the top and somehow latch on through the center? Any guidance would be mich appreciated
post #3 of 6 (permalink) Old 09-16-2014, 10:43 PM
2000 VN 750 Senior Member
I had a right front foot peg break off and all I did was use a small screw driver to slip off the spring clip at the one end and then tap out the pin till I could grab it and pull it out the remainder of the way by the head with a channel lock or vise grip. Be sure to look at the placement of the spring so you set it up the exact same way for reinstallation. I took a picture with my phone just for a quick reference. The installation of the new peg is just as easy. Hold the new peg in place with the spring in the proper location and slide the pin back in. I used a needle nose plier to get the end clip back in place. It took less than five minutes from start to finish. Good luck.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #4 of 6 (permalink) Old 09-16-2014, 10:52 PM
Yeah dude that pin comes out if you remove the retaining clip that is at one end. Look closely.
post #5 of 6 (permalink) Old 09-17-2014, 07:19 PM Thread Starter
Sweet. Took less then 5 minutes mainly due to the spring getting in the way from the pin going all the way back in lol. Amazing response time guys thanks a lot!
post #6 of 6 (permalink) Old 09-17-2014, 07:33 PM
I told you it took less than five minutes. I am glad you were able to take care of that.
Tom
Vulcan 2000
4507 miles
