fork brace - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 10-17-2007, 04:29 PM Thread Starter
fork brace
OK, getting ready to check/replace wheel bearings and I thought , well if i am going to put on a fork brace, this is the time to do it. I would like some input on the brace, I have no experience with them at all, I understand the concept, but I figure someone on here has one or at least can shed some light my way, just don't know if it is worth the money, thanks to all.
mymark66 is offline
post #2 of 9 (permalink) Old 10-17-2007, 04:42 PM
According to the Superbrace site:
"fork stabilizer that...reduces speed wobbles, fork flex, front tire wear and rain groove sensitivity while dramatically improving overall handling and front-end stability."
And from what I've heard they work well. I also heard that the clearance between the brace and fender is about 2 pages thick.
2001 VN750
Vista Cruise Control
V-Force shield
Kawasaki Saddlebag supports
Fixed trunk hinge
TOC MCCT
Clear Alternatives LED tail light
Knifemaker style floorboards
Knifemaker style dash
Avon Venom X 110/90 Front
Avon Venom X 170/80 Rear
Big Crank AGM battery
25,100 miles as of 04/20/2010
lancer19 is offline
post #3 of 9 (permalink) Old 10-17-2007, 04:50 PM
I put one on my Vulcan, and did notice a diffrence. (for the better)
I think all bikes should have them, as they just make sence. (If you understand physics)
Just be sure the forks go up and down smoothly and do not bind. If you do not have progressive springs in your forks, I would do that first, or if you have the time and money, do both..
post #4 of 9 (permalink) Old 10-17-2007, 06:44 PM
2FAS4U
I noticed a difference right after installing. Cornering was much more stable.
2fas4u is offline
post #5 of 9 (permalink) Old 10-17-2007, 11:22 PM
Ok...maybe a dumb question, but do you need to change the fork seals when you change the springs?
2001 VN750
V-Force shield
Fixed trunk hinge
TOC MCCT
lancer19 is offline
post #6 of 9 (permalink) Old 10-18-2007, 12:07 AM
No. You only need to replace them if they are leaking. There are several write ups in the Verses on installing the Progressive springs.
Changine springs is fairly easy, changing seals is a bit of a pain............
post #7 of 9 (permalink) Old 10-18-2007, 09:38 PM
james brill's Avatar
a dumber question,where do you find braces for our model?or do you have to make your own?
james brill is offline
post #8 of 9 (permalink) Old 10-18-2007, 10:04 PM
Loran in Npvl IL's Avatar
www.superbrace.com $$$$$
anyone know of any cheaper?
Deuce (Loran Naperville IL)
2003 VN750
- Corbin seat w backrest
- Progressive suspension.
- Kury iso goldwing grips
2 1983 V65 Magnas
Loran in Npvl IL is offline
post #9 of 9 (permalink) Old 10-18-2007, 10:06 PM
http://www.superbrace.com/proddetail.asp?prod=4434
edit...don't think you will find one cheaper, and if you did, would you trust it?
