Calipers?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 24 (permalink) Old 09-25-2007, 11:57 AM Thread Starter
Kys
Angry Calipers??
I have a 93 vn750 that has been in the shop forever. I described my multiple issues in the newbie forum. I'm still being told that they are unable to bleed the breaks and that the calpers are the last thing they can try to replace. OEM caliper assembly is $267.00 each...this is crazy. I am going to look on ebay for used ones but just want to get my bike on the road ASAP. Any ideas???
Kys is offline
post #2 of 24 (permalink) Old 09-25-2007, 12:38 PM
If the calipers need replaced. Ebay would be the first place I'd go. But I don't understand why they can't bleed the breaks.Good luck!
If you don't have a copy. Repair manual.
http://www.tocmanufacturing.com/Products.htm
(The manual is under "Other Links"
post #3 of 24 (permalink) Old 09-25-2007, 12:57 PM
93VN750's Avatar
Most of us have found that bleeding brakes as best as possible, then tieing the brake lever fully tight over night, then bleeding one more time does it.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #4 of 24 (permalink) Old 09-25-2007, 01:39 PM
Crobins365's Avatar
There was a full set of calipers and hoses on eBay just the other day - oops, they sold yesterday. But here are two full sets for sale: item number 170151126544 and number 330169262790 (although I don't like the looks of the hoses on that). And there's also a listing for the calipers separately (left and right - two different listings). I still think your calipers could probably use a good cleaning, maybe you need new pads (who doesn't? ), and then someone competent-not-at-your-shop to bleed the lines. Worst case scenario, replace the hoses.
Did you ever get in touch with Mark (Foxhound)?
Again, I'd grab my bike from the chop shop, download the manual for which kanuck posted the link, and hit up eBay for parts. And the Forum for tech advice.
Crobins365 is offline
post #5 of 24 (permalink) Old 09-25-2007, 03:32 PM
Sound to me like your shop is ****ing you over. (..pardon my french...)
I agree, get the bike out of there before you end up spending more money and get a manual and do it yourself...
post #6 of 24 (permalink) Old 09-25-2007, 03:37 PM
Spriddle's Avatar
Jon
Yep thats what I had to do.
And I couldnt agree more, If they cant bleed them, find a new shop
Steve from Pittsburgh
2005 vn750
modified knifemaker driver boards
chrome levers, Shaved saddle
Ape manual CCT's, nylon saddle bags
engine mount covers, plexIII windshield
crash bar w/floor boards, air hawk pad
ear mod, rad cover/,w/ss mesh
chrome cable and wire covers
chrome anti-freeze cover
RR relocation,MF battery,drilled out
idle plugs,marbled
Spriddle is offline
post #7 of 24 (permalink) Old 09-25-2007, 05:10 PM
Sound to me like your shop is f(censored)g you over. (..pardon my french...)
lmao That's the first time I've seen anyone actually type out the whole spelling here. I was just thinking the other day how decent everyone is. And no I'm not offended in any way. I actually have found it to be one of my more common words. lol Nice to someone being straight forward. There's nothing worse than someone screwing you! (& you didn't want to be screwed!) bsides I'm censored Damb that makes 3!
post #8 of 24 (permalink) Old 09-25-2007, 05:50 PM
Crobins365's Avatar
There was an issue about some ribald language in a post recently - I can't remember the details, 'cept one Forum member noted that his granddaughter reads the posts and he was hoping we'd keep it clean. Might wanna go back and edit that, just as a courtesy to whoever's reading.
That said, I agree on the shop assessment. The brakes are a closed system - if you can't bleed 'em, there's a very limited number of things that can be the problem, though my guess is it's in the hoses, not the calipers.
Hey, anyone wanna open a shop on the Eastern Shore of Maryland with me?
C
post #9 of 24 (permalink) Old 09-25-2007, 11:55 PM
Why not a traveling shop? Tour the country and fix VN750's!
I'd go for that!!
Have wrench will travel.
2001 VN750
Vista Cruise Control
V-Force shield
Kawasaki Saddlebag supports
Fixed trunk hinge
TOC MCCT
Clear Alternatives LED tail light
Knifemaker style floorboards
Knifemaker style dash
Avon Venom X 110/90 Front
Avon Venom X 170/80 Rear
Big Crank AGM battery
25,100 miles as of 04/20/2010
lancer19 is offline
post #10 of 24 (permalink) Old 09-26-2007, 07:55 AM
2FAS4U
Let me know if you end up needing 1 or both calipers. I should have some in the garage. PM me when you find out.
Dave
2fas4u is offline
