brake caliper spring location - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-13-2014, 06:10 PM Thread Starter
emtdon's Avatar
this is a crazy question could someone pull a caliper and take a picture of where the pads set in the flat spring that holds the pads in place. i would really,really appreciate it. thanks
or explain how it goes. it is the spring under the pads.
Sent from Motorcycle.com App
2003 kaw vn 750 pushing 40,000 miles.
tp stator
dampers
coil relay mod
other stuff not listed
mustang seat
motorcycle repair at a stealership 1 million bucks, repairs with the help of the Vulcan750 forum priceless.
emtdon is offline
post #2 of 5 (permalink) Old 05-28-2014, 07:56 PM Thread Starter
emtdon's Avatar
does the pad go in front of the tabs on the spring or behind them? is the pad in the correct place? thanks.
ID:	16025   Click image for larger version
tp stator
dampers
coil relay mod
mustang seat
emtdon is offline
post #3 of 5 (permalink) Old 05-28-2014, 08:03 PM Thread Starter
emtdon's Avatar
here is a side view
tp stator
dampers
coil relay mod
mustang seat
emtdon is offline
post #4 of 5 (permalink) Old 05-28-2014, 08:04 PM Thread Starter
emtdon's Avatar
the inside pad seems to be pretty loose
tp stator
dampers
coil relay mod
mustang seat
emtdon is offline
post #5 of 5 (permalink) Old 05-30-2014, 09:31 PM
The ear in the middle of the pad, sits in front of the tab on the spring. If the tab could push on the pad, it would push it toward the rotor.
