installing bearings - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 05-08-2014, 04:28 PM Thread Starter
emtdon's Avatar
installing bearings
when installing bearings how do you know when they are seated far enough. are they supposed to be against the spacer inside the wheel?
Sent from Motorcycle.com App
2003 kaw vn 750 pushing 40,000 miles.
tp stator
dampers
coil relay mod
other stuff not listed
mustang seat
motorcycle repair at a stealership 1 million bucks, repairs with the help of the Vulcan750 forum priceless.
emtdon is offline
post #2 of 2 (permalink) Old 05-08-2014, 04:48 PM
I will take this on.
Yes. Anything less is dangerous. On a motorcycle wheel, the smaller /inner bearing race MUST be captive. the outer/larger race must be captive as well, but has multiples less leverage/loading. This was true before disc brakes required disc alignment.
Ball brgs are only 100% loaded in one plane. They are NEVER 'preloaded' out of that plane. No lateral preload.
Tapered bearings are designed to sustain multi-plane loading and are usually preloaded. Preloading is required to keep the rollers in contact with both tapered races. The more severe the multi-plane loading, the higher the preload and the shorter the bearing life. Opposed (2) tapered bearings will take designed loading from any angle.
HTH.
edit for clarification-the inner spacer should be tight in between/against both inner bearing races. Between the forks, there has to be a combination of spacers and inner/smaller bearing races that 'stack' tightly.
wmsonta is offline
