cleaning rotors - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-06-2014, 12:13 PM Thread Starter
emtdon's Avatar
cleaning rotors
can rotors be wet sanded to make them smooth
Sent from Motorcycle.com App
2003 kaw vn 750 pushing 40,000 miles.
tp stator
dampers
coil relay mod
other stuff not listed
mustang seat
motorcycle repair at a stealership 1 million bucks, repairs with the help of the Vulcan750 forum priceless.
emtdon is offline
post #2 of 5 (permalink) Old 05-06-2014, 12:31 PM
By hand? I'd say no. How can you be sure you're sanding them perfectly even?
From what I understand the vulcans rotors can't/shouldnt be turned, they should be replaced if gouged up badly.
post #3 of 5 (permalink) Old 05-06-2014, 01:17 PM
Yes, depending how much material you are trying to remove.
A light sanding to remove glazing could be done by hand using a paint stirrer for a block, a body man I know swears by a flat piece of plastic. Scotchbrite might take glazing off and wouldn't remove metal.
Ideally, you would want to lay the paper on something perfectly flat (sheet of glass) and move the part over the paper, but a lot of people have trouble with the rotor bolts.
Sounds like something I should do when I have my forks apart soon. Have some dark smudges on mine I think, haven't seen the ole girl for a while.
A good wash with soap and hot water, then flooding rinse would be good after. Maybe watch the braking until you're adjusted to it and things burn in again.
post #4 of 5 (permalink) Old 05-06-2014, 05:12 PM Thread Starter
emtdon's Avatar
i thought maybe like 2000 grit sand paper but a scratch pad sounds better. not really to reduce the surface just to clean rust and other dirt on the surface
tp stator
dampers
coil relay mod
mustang seat
emtdon is offline
post #5 of 5 (permalink) Old 05-06-2014, 08:27 PM
I use 800 emery to take glazing off, and hit it at a 45 deg angle to the outside edge....and Knife is right, they cant be "cut", unless they are still within tollerances....from what i understand, EBC is now making rotors with extra meat....
