Stange noise in left fork - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 09-04-2007, 09:59 AM Thread Starter
Taras_s's Avatar
Last times apiars a strange noise in left fork: knoking like washer knocks of case.
Have somebody the same problem?
Taras Stets
86' VZ750
Varta 18 Ah
don't wont,but need to R/R relo,
Ukraine, near Kiev
Taras_s is offline
post #2 of 8 (permalink) Old 09-04-2007, 02:11 PM
Are you sure nothing was hitting the fork, such as any wires or cables?
Also, how are the front brakes and rotors? I managed to get a small dent in my left rotor which now makes a noticable 'bump' when I use the front brakes. A little more sanding and I'll have that fixed easy enough.
post #3 of 8 (permalink) Old 09-04-2007, 03:08 PM
Spriddle's Avatar
Check those front fender bolts,they can get loose,mine did.
Steve from Pittsburgh
2005 vn750
modified knifemaker driver boards
chrome levers, Shaved saddle
Ape manual CCT's, nylon saddle bags
engine mount covers, plexIII windshield
crash bar w/floor boards, air hawk pad
ear mod, rad cover/,w/ss mesh
chrome cable and wire covers
chrome anti-freeze cover
RR relocation,MF battery,drilled out
idle plugs,marbled
Spriddle is offline
post #4 of 8 (permalink) Old 09-05-2007, 03:57 AM Thread Starter
Taras_s's Avatar
Nothing else can hit on fork, all of this things was tied with rubber? when I search what wrong?
When fornt wheel in air and I hit it up and down then I hear that noise! Noise like bolt shakes in pan!
That noise heared when I rod by inertion, I mean no acceleration or decceleration.
Taras Stets
86' VZ750
Varta 18 Ah
Ukraine, near Kiev
Taras_s is offline
post #5 of 8 (permalink) Old 09-05-2007, 04:06 AM
Hmm, have you tried removing the wheel to compare the left fork movement to the right fork?
I would think if something came apart or broke inside the fork, there would be a difference in how it feels.
I'm just guessing here. I haven't been into the forks yet.
post #6 of 8 (permalink) Old 09-05-2007, 08:48 AM Thread Starter
Taras_s's Avatar
Well I have been into the forks, and this is worry me.
Couse If I repaired something it brakes again. I have change a seals in fork -now I have problem with fork.
I repair balancers - have a problem with them+ stator, I think becouse vibration.
One positive moment that I have is that - I still riding!
Taras Stets
86' VZ750
Varta 18 Ah
Ukraine, near Kiev
Taras_s is offline
post #7 of 8 (permalink) Old 09-12-2007, 09:07 AM Thread Starter
Taras_s's Avatar
Well It wasn't a fork. It was brake pad -it almoust dropes frome holder. It is below service limmit.
Taras Stets
86' VZ750
Varta 18 Ah
Ukraine, near Kiev
Taras_s is offline
post #8 of 8 (permalink) Old 09-12-2007, 02:26 PM
Well, that should be an easy fix!! Glad it wasn't anything in the forks!
