Axle nut - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 04-20-2014, 10:55 AM Thread Starter
Axle nut
I am having a time getting the axle nut loose to get my front tire off, my crazy question is, is it suppose to come off?
Gtay1g13 is offline
post #2 of 10 (permalink) Old 04-20-2014, 11:15 AM
Yes it will come off. What exactly is the trouble? A little more info and we can figure out how to help out.
post #3 of 10 (permalink) Old 04-20-2014, 11:30 AM
Theres a nut clamping the axle on the left side looking at the bike from the front.
post #4 of 10 (permalink) Old 04-20-2014, 12:07 PM Thread Starter
Trying to take the front wheel off and the nut that holds the axle on the right will not budge. Only thing I haven't used is an air gun to take it off
Gtay1g13 is offline
post #5 of 10 (permalink) Old 04-20-2014, 12:21 PM
Have you tried a breaker bar? How about smacking the handle of your ratchet with a hammer?
post #6 of 10 (permalink) Old 04-20-2014, 12:48 PM
Pb blaster?
post #7 of 10 (permalink) Old 04-20-2014, 04:44 PM Thread Starter
Hammer thing
I tried hitting socket with hammer but the socket just moves and I'm afraid of messing the nut up
Gtay1g13 is offline
post #8 of 10 (permalink) Old 04-20-2014, 07:15 PM
If you are using the correct size socket it should not slip when using a breaker bar or a regular ratchet. Make sure you are using the correct 19mm socket.
post #9 of 10 (permalink) Old 04-20-2014, 07:54 PM
is it the 19mm nut or the cinch bolt on the other side thats acting up?
michiganteddybear is offline
post #10 of 10 (permalink) Old 04-20-2014, 09:39 PM
Concert connoisseur
wib714's Avatar
x2 pb blaster, keep it off your tire though
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
