pot holes and bumps - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 23 (permalink) Old 03-04-2014, 11:45 PM Thread Starter
pot holes and bumps
Hi folks, My Vn is a '93.. don't know if the folk oil and springs have ever been changed... she hits hard on the bumps.. I try to avoid the pot holes.. would it soften the blows if I change it out?..
Grace is offline
post #2 of 23 (permalink) Old 03-05-2014, 12:34 AM
Mine is a '93 also. Last season I noticed bad suspension on front; hard on bumps, and seemed like the tire left the roadway. I found very old oil, water intrusion ( creamy white) and a difference in oil amounts. I drained, swabbed inside. Replaced with required amount of oil. Also my spacers were 9 5/8" long. I cut new ones @ 10 3/16". Ride a lot nicer over bumps, and the rebound keeps the tire on the ground more. Very noticeable feel of control.
smltownr is offline
post #3 of 23 (permalink) Old 03-05-2014, 12:41 AM Thread Starter
cool, thank you.. but, I'm a bit confused.. you have to cut the springs to length?... I figured I could get a pre fabbed kit.. I do like you idea of increasing the the length.. you talking about the spring right?.. I'm newby mechanic.. I fixed some electrical issues and changed the ACCTs ..about it.. but, I love this bike..and I wanna do her right..
Grace is offline
post #4 of 23 (permalink) Old 03-05-2014, 12:43 AM
He's talking about the preload spacers, not the springs.
post #5 of 23 (permalink) Old 03-05-2014, 12:45 AM Thread Starter
opps.. you are talking spacers.. I was talking springs... appentlentyl I need more reseach... are the spings and issue as well?
:doh
Grace is offline
post #6 of 23 (permalink) Old 03-05-2014, 12:49 AM Thread Starter
are the springs an issue as well?
Grace is offline
post #7 of 23 (permalink) Old 03-05-2014, 12:54 AM Thread Starter
I have no problem keeping the tire on the ground... It just hit so hard it wears me out.. the roads arehorrible in Michigan
Grace is offline
post #8 of 23 (permalink) Old 03-05-2014, 01:06 AM
The stock springs are ok.try changing your fork oil first.then play with preload if you are not happy.might even go with a lighter oil.some of the other guys will chime in that are a little more knowledgeable than me.I have played with other bikes forks but not my Vulcan yet
post #9 of 23 (permalink) Old 03-05-2014, 02:14 AM Thread Starter
sounds like a good place to start .. thankyou..
Grace is offline
post #10 of 23 (permalink) Old 03-05-2014, 06:41 AM
You are welcome
