Rubber Boots on Brake Caliper Posts - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 07-07-2007, 08:22 PM Thread Starter
There are rubber boots on the caliper bracket posts, upper and lower. I have 3 that seem to be somehow seated firmly at each end.
One upper boot rotates easily with my fingers. However, it is in contact with the caliper bracket on one end and caliper body on the other end. Do I need to be concerned about the possibility of brake fluid leakage or contamination at this location? Or is there just lubricant on the posts?
Just had a brake job at the end of May and noticed the boot was not seated tightly like the other 3 today. No tears in it.
Victor is offline
post #2 of 2 (permalink) Old 07-07-2007, 09:21 PM
If I understand where you are talking about there is no possibilty of brake fluid leakage. The piston moves in the caliper bolt and has o-ring like seals. The caps you describe are probably bleeder caps used to keep dirt out. If you have fluid around them wipe them dry and check that the bleeder is tight. Probably from where your mechanic didn't wipe the fluid off.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
