Rear shock absorber - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 01-26-2014, 04:48 PM Thread Starter
kemen3's Avatar
Rear shock absorber
I am working on lubing the splines on my bike. Just wondering if I should do anything with the rear shock absorbers while they are off. I have been told that you should change the oil out in them every so often. Just wondering if this is true. If so what are the steps on doing that? Thanks
kemen3 is offline
post #2 of 15 (permalink) Old 01-26-2014, 09:00 PM
Chasin' the blacktop
Spencer1's Avatar
I wasn't aware that the rear shock oil could even be changed.
North Georgia
Spencer1 is offline
post #3 of 15 (permalink) Old 01-26-2014, 09:02 PM
Yes you can split then apart
post #4 of 15 (permalink) Old 01-26-2014, 09:46 PM
Spencer1's Avatar
Doc, you are joking right??? or am I missing something?
North Georgia
Spencer1 is offline
post #5 of 15 (permalink) Old 01-26-2014, 09:49 PM
Am not sure how it's done and probably isn't feasible but they do come apart
post #6 of 15 (permalink) Old 01-26-2014, 09:55 PM
There's a drain on the stock ones I think....you'd need to refill thru there or thru the air valve I guess (remove spring, pump em out)....but honestly, unless it has 50k on it from a 300lb rider, shouldnt need to.....easier to just get new/used shocks....if yours are leaking, you need to anyway...Harley Sportster shocks will work with a bushing swap, and shocks of EN 454/500s are bolt ons...thats what Im runnin now...no air, but 5 way adjustible like stock....
post #7 of 15 (permalink) Old 01-26-2014, 09:58 PM
And bushings press out easily
post #8 of 15 (permalink) Old 01-27-2014, 06:41 AM
Ndr
Shock Oil Refill as presented by Roach.
I'd be interested in figuring out how to disassemble the shocks for a thorough cleaning and getting rid of the rust so that I can repaint them, possible two toned.
Ndr is offline
post #9 of 15 (permalink) Old 01-27-2014, 08:21 AM Thread Starter
kemen3's Avatar
Thanks for the info. Since there is nothing wrong with them I will just leave them go for now.
kemen3 is offline
post #10 of 15 (permalink) Old 01-27-2014, 04:57 PM
unscrew the valve stem....dump oil out....refill...replace valve
It really is that easy!!
