Front Brake Squeak - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 10-08-2004, 10:01 AM Thread Starter
Front Brake Squeak
New 2005 Vulcan 750
I noticed the front break squeaks a little when stopping.
After the first 190 miles at about 225 miles now.
Is this normal on a new bike and will go away or should I mention it when I get the 500 mile service if it still is happening?
Its not a super loud noise - I just didn't expect it.
I love this bike - Its so fun and easy to ride
Looking forward to getting out of the break in period to rev it up.
Flyinv is offline
post #2 of 9 (permalink) Old 10-08-2004, 11:50 AM
Re: Front Brake Squeak
I have almost 13k on my 2002 and the front brake still occasionally squeaks.
jdegreif is offline
post #3 of 9 (permalink) Old 10-09-2004, 10:10 AM
Originally Posted by Flyinv
New 2005 Vulcan 750
Fly...you can eliminate this if you want.
Take off the calipers and apply some disc brake grease to the backs & sides of the pads (NOT the pad material itself!), as well as the spring tensioner under the pads. Then make sure the pads, esp the small one, are properly seated.
You can do this yourself if you're carefull, or get the dealer to do it for you when you bring your ride in for it's first check up...
jm1515 is offline
post #4 of 9 (permalink) Old 10-10-2004, 08:54 PM
Thumbs up Re: Front Brake Squeak
If anyone is going to pull a caliper then you might as well sand the rotor by hand and also the do the pads lightly. I did when I bought my Vulcan used and again just recently when I installed my new DP sintered metal pads. Never had a squeak with the oem pads or the DP pads which I just broke in. Yes, they have better initial bite than the stockers and cost less. Now do use some elbow grease when sanding the pads with 3M 100 grit Garnet sandpaper which is just plain old wood sandpaper. It took a boatload of research to find out what was truly the best stuff to sand with and most of us already have some in the garage! I haven't greased anything in my brakes, just cleaned 'em up with rags, Q-tips and Kerosene when I had em off to istall the DP pads.
Bruce is offline
post #5 of 9 (permalink) Old 12-31-2004, 04:20 PM
I have an 05 750 also and it still squeaks a little bit with 1800 miles on it.
rock is offline
post #6 of 9 (permalink) Old 12-17-2006, 09:53 AM
Avid Rider
stevebtx12's Avatar
Send a message via Yahoo to stevebtx12
My '94 has always had a touch of front break squeak occasionally (seems almost weather related), I've just learned to live with it...lol.
Steve in TX
'06 VN1600 Classic
V&H Bigshots
F&S windshield/lowers
Mustang seat/driver backrest
OEM saddle bags/Easy brackets
Phatt II risers
Cobra fatty highway bar/Kury Dually highway pegs
Cobra sissy bar/luggage rack
Iso Flame grips/throttle boss
VROC #22372
"Some days you're the windshield, some days you're the bug." (me)
stevebtx12 is offline
post #7 of 9 (permalink) Old 12-17-2006, 01:47 PM
Geek
rnewell's Avatar
My '05 has 4800 miles, never heard a squeek.
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
post #8 of 9 (permalink) Old 12-17-2006, 05:08 PM
Crobins365's Avatar
I'm not sure what the composition of pads is on the new bikes, but I have changed out pads on other bikes from stock to organic to eliminate the squeak. Well, if it's just a little squeak, it may be okay; if it's starting to squeal (which was happening on my partner's bike) change the pads (or follow any of the above advice - especially putting stuff on the back of the pads) before it drives you insane. The organics are nice.
C
Crobins365 is offline
post #9 of 9 (permalink) Old 01-13-2007, 04:47 PM
MANIC MECHANIC
vulcanjoe's Avatar
silicone brake caliper grease
My bike just tripped 30000 miles I installed new wheel bearings and brake pads they squealed from the moment that i put them on. I used a couple of products that we use on customers cars at work. The first was a silicone based grease made by crc. I applied it to the backs of the brake pads. Then I scuffed the friction side with a red 3m scuff pad and put a product called
BG stop squeal. It is available at most automotive repair shops you put it on the friction side and it will dry to a dull finish and just install on the bike have not had a problem since.
Drew
vulcanjoe is offline
