Loose side stand - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 11-22-2013, 02:36 AM Thread Starter
'03 VN750 "Rosie"
bstew7890's Avatar
Loose side stand
I was thinking my bike leans pretty far over on her side stand. When extended, the tip of the stand has about 2inches of up/down play. Is this normal? The play is at the pivot point;the bracket is not loose.
Thanks!
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
post #2 of 4 (permalink) Old 11-22-2013, 08:18 AM
Thanks!
sounds like the hole the sidestand bracket may be worn elongated.You might ought set it on the centestand and remove the bolt and see if it is worn,the bolt and the hole. A little movement is normal but if it feels like it is going to lay down,check it out watch for the spring it has a bit of pressure on it. Easier to take apart when it is folded up against the frame.
One of the most overlooked points to lube on a bike.
post #3 of 4 (permalink) Old 11-22-2013, 08:37 AM
mine is similar.. yes, the hole in the side stand is elongated on mine. toyed with the idea of drilling out the hole and putting is a bushing so it matches the body of the bolt, but have decided to leave it as is.
No kidding on that spring.
post #4 of 4 (permalink) Old 11-22-2013, 09:03 AM
This is a common problem. Most fix this just getting a larger diameter bolt, and drilling out the hole round again with a step drill.
