Front fork leaking after lay over. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 09-26-2004, 11:45 PM Thread Starter
Question Front fork leaking after lay over.
I was trailering my bike home after taking my cycle endorsement test and I took a sharp turn and over she went. Luckly it landed on the spare tire of the trailer and didn't cause any damage, but now the right fork is getting oil on it. I changed the seals in early spring and had no oil showing till the bike laid over. It seems to not be changing but is getting oil on it everytime I ride. Any suggestions will be greatly appreciated.
SlaterVN750 is offline
post #2 of 4 (permalink) Old 09-27-2004, 10:38 AM
Re: Front fork leaking after lay over.
Hopefully you did not bend a fork and only dislodged a seal when it tipped over.
I would take the wheel off and check very carefully that the forks are still aligned and not binding, then re-check the seals.
Hope it's a bad seal and not a 'torqued fork'....
jm1515 is offline
post #3 of 4 (permalink) Old 09-27-2004, 02:02 PM
If you really cranked the front forks down with ratcheting straps on the trailer, you might have blown the seals. I'm told that you should not compress the shocks more than half-way down when transporting to avoid doing that. If that is not the problem, follow suggestions in previous reply.
daviddowns2000 is offline
post #4 of 4 (permalink) Old 09-27-2004, 06:37 PM
After re-reading your post, it soesn't sound like strapping the bike down too tight was the problem!
