Minor front disk brake sqeal - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 04-13-2007, 10:59 PM Thread Starter
flw
Just today the front disk brake started to squeal even on normal or light usage. What is suggested that I can just spray on to clean minor dust? I want to avoid any type that is motorcycle only. Can I get something that can be used on auto's as well? No cycle dealers in the area.
I live in a area with a lot of construction and farms. Dust and dirt are normal. So I'm just trying to maintain clean brakes in a dirty environment.
Thanks for any help.
flw is offline
post #2 of 5 (permalink) Old 04-14-2007, 03:06 AM
You might just need to give the brake pads and disk a light going over with some fine sandpaper to remove any glazing thats built up on them.
Some anti-squeal behind the pads might help too.
Do you know how many miles are on the brakes?
post #3 of 5 (permalink) Old 04-14-2007, 02:02 PM
Crobins365's Avatar
If you use some kind of brake cleaner (acetone), that'll dissolve anything that might be on the rotors - but make sure you keep it away from rubber parts. It'll dissolve those, too, if contact is too long.
One product that Hyper's talking about is something called "Disc Brake Quiet" (mfg'd by CRC, sold at NAPA under that name). Use it behind the brake pad to eliminate chatter.
C
Crobins365 is offline
post #4 of 5 (permalink) Old 04-23-2007, 03:21 PM
fergy's Avatar
Maybe your pads are just hardened and need replacing? How many miles on them? How much pad is left?
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #5 of 5 (permalink) Old 04-23-2007, 03:43 PM
93VN750's Avatar
You can used compressed air and blow out the area between the pads and the disk. Use caution as you would not want to be inhaling this.
Then clean both sides with some BrakeKleen, as Cindy said, for brakes only.
If still noisy, some antichatter on the back of the pads may help.
Possible the pads are glazed and need to be replaced? Brake lever pressure any higher than before?
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
