Cheaper sight glass replacement, custom size & thickness - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 07-26-2013, 12:21 PM Thread Starter
I.T. Analyst, Alpha Geek
FieroGT42's Avatar
There is no replacement part # for our brake fluid sight glasses, and the only part I can find is on eBay with about 450% markup, and the guy wouldn't even tell me what kind of adhesive I'd have to buy for his kit until I bought the glass. That was a big turn-off to me because I want to know the hidden costs.
I found some alternatives though. Here's a website where you can order glass for watches in any thickness and any diameter to within 1/10 of a mm of what you need. I'm sure there are many others: http://www.esslinger.com/watchcrysta...eralglass.aspx. Edit: This place has them as well but 3x at a time and $15 minimum:
At the first website, they're about $2.50 vs $15 for the eBay kit. With shipping it comes to a whopping $3.50 to your door. I bet they would also be suitable for the crankcase oil sight glass if you got the right size.
I got some measurements with my micrometer. They're taken using my old (1986) plastic sight glass and old o-ring. Bike is a 1986 VN750, stock.
Stock plastic sight glass
Inside groove for o-ring: 21.3 mm O.D. average (slightly oval)
Ridges inside/outside o-ring: 22.4 mm O.D. average
Master cylinder:
Sight glass bore: 22.50 mm, dead on in 3 spots. I'm pretty confident on this reading. (your glass must be a hair smaller)
O-ring I.D.: 21 mm just touching (This is old and somewhat flattened)
O-ring backspacing: 2.5 mm from slotted readout face
O-ring thickness: about 3 mm deep
I'd suggest glass 2.5 mm (back of o-ring) to 4 mm thick (center of o-ring depth) depending on how much contact you want with the o-ring.
RTV is supposed to hold up to brake fluid. I plan to use super black because I have it on hand.
Photos of my installation when I get my glass in the mail. I'll try to remember to update this thread.
Jason
FieroGT42 is offline
post #2 of 2 (permalink) Old 07-26-2013, 01:44 PM
Roach's Avatar
Nice Find!
I think I didn the ebay thing with mine, and it's just a piece of glass, nothing special.
I'm pretty sure I used Super Black as well. No problems.
Street
1985 VN750 Acquired Feb, 2011 - 13,676km
Mods - Ear Shave, Pickup Coil Gap, Drilled Clutch Basket, Shift Tie Rod, Mosfet R/R, MF Battery, De-Goated (H-Pipe), MCCT, Heated Grips, Plexistar 2 Windshield
Dirt
2004 KTM SX 125 - 1979 Can-Am Qualifier 250 - 1971 Kawasaki F6
Video Tutorials - Engine Rebuild - Fork Seal Replacement - Grease Swing Arm Bearings - Carb Rebuild - Spline Lube - Refilling Rear Shocks - Grease Steering Bearings
Roach is offline
