tire pressure - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 12-18-2006, 03:18 PM Thread Starter
Rider on the Storm
EasyRector's Avatar
Question tire pressure
My owner's manual tells me that the best tire pressure for my stock Bridgestone tires is 28 psi (front) and 32 psi (rear). (I have 4000 miles on them.)
I've also asked various Bridgestone and Kawasaki reps, and they all say that: 1) lower pressure (e.g. 28/28) provides a smoother ride, and 2) higher pressure (e.g. 36/38) will reduce wear on the tires. Invariably, however, they defer to the owner's manual recommendation because that's what the Kaw engineers have determined.
I'm wondering what all of you think?
I will probably go for a tire upgrade somewhere between 6000 and 9000 miles.
By the way, I'm now using a digital ROADGEAR Tire Pressure Gauge. So far I really like it. Theoretically, it's very accurate (+/- 1%), has a lithium battery which will last "forever", and a 5-year warranty. It even "talks" to me, which is not nearly as annoying as I had anticipated. (I had originally used an Accugage with hose, but it was off by around 4 psi according to the local tire center, so I returned it.)
EZC
EasyRector is offline
post #2 of 11 (permalink) Old 12-18-2006, 03:36 PM
Avid Rider
stevebtx12's Avatar
Send a message via Yahoo to stevebtx12
Maybe they've changed the owner manual since I got mine (a '94'), it recommends ranges - front 26 - 28, and rear 28 - 32. So, with just me, I go with the 26 front, 28 rear, and will go up to 28 front, 32 rear if I'm going to be taking a passenger. Just my 2 cents worth.
Steve in TX
'06 VN1600 Classic
V&H Bigshots
F&S windshield/lowers
Mustang seat/driver backrest
OEM saddle bags/Easy brackets
Phatt II risers
Cobra fatty highway bar/Kury Dually highway pegs
Cobra sissy bar/luggage rack
Iso Flame grips/throttle boss
VROC #22372
"Some days you're the windshield, some days you're the bug." (me)
stevebtx12 is offline
post #3 of 11 (permalink) Old 12-18-2006, 07:07 PM
Uber Member
i prefer the higher values.... infact I run 29-30 in the front tire. this is in part cause i am heavier, i weigh in around 210 without gear. I've found the higher values make ride a lil rougher, but improve handling.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #4 of 11 (permalink) Old 12-19-2006, 03:00 AM
Originally Posted by Hizzo3 View Post
i prefer the higher values.... infact I run 29-30 in the front tire. I've found the higher values make ride a lil rougher, but improve handling.
Same here. The slight bit more roughness in the ride doesn't bother me that much. And the better handling is more important to me.
I broke my butt in on the dirtbike seats, and haven't had any ride on the Vulcan beat me up like those seats do on the trails!!
I'd suggest.......
Finding a particular route you enjoy, and do often (some twisties, or atleast slightly sharp turns and straight aways). Say something around 25 miles (just a suggested amount, do what you're comfortable doing)
Do the route a couple times with the slightly lower amount of pressure. Pay attention to how the bike handles/reacts to the road, to the comfort level, and to the mileage as well.
Then pump a few more pounds in, and try it again. See what differences there are and determine which way you'd rather it be.
I don't mean to do this all in one day (unless that's what your up for ) but do the same route every time so you can easily recognise the different way the pressure effects your riding style. Because the factory only put those #'s as suggestions. Besides, would you trust a manufacturer that doesn't lube the splines ??!!!
post #5 of 11 (permalink) Old 12-19-2006, 07:27 AM
Crobins365's Avatar
I ride with the higher pressures (30 fr, 32 r) as well, for the reasons everyone else noted (less wear on the tires, zippier ride). If you think you might end up having to ride in the rain (e.g., you ride to work, the weather forecast is iffy), I'd suggest dropping that to 28/30 - a little more tire surface on the road is always a good thing in slippery conditions. I do like Hyper's suggestion, however, for taking 'er out and seeing what you prefer for your everyday ride.
Come to think of it, perhaps I'll do that myself when I get back home - if this little period of global warming continues. I'm in Stamford, CT until Thursday - isn't there someone on the Forum from up this way?? Gosh, I could use a ride.
C
Crobins365 is offline
post #6 of 11 (permalink) Old 12-19-2006, 08:02 AM
"ya can't live forever"
artman's Avatar
Dunlop 404s 34 front 41 rear. Hard but very responsive.
artman is offline
post #7 of 11 (permalink) Old 12-19-2006, 10:21 AM Thread Starter
Rider on the Storm
EasyRector's Avatar
Ha!
EZC
post #8 of 11 (permalink) Old 12-19-2006, 10:44 AM
fergy's Avatar
I'm riding on Dunlop 404's too, same pressure as Artman. I weigh in at 265 plus gear so I keep em hard. Have my rear shocks aired up to 41 as well.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #9 of 11 (permalink) Old 12-19-2006, 01:49 PM
EDALBRIS's Avatar
155/85/15 Car Tyre On Rear 15 Psi With Side Car 5 Psi Without And No Rear Suspension(hardtail+5").
Not Much Help I Know But Was Bored And Thought I Would Join In.
BEST OF HEALTH AND HAPPYNESS
EDALBRIS
1952 NORTON (MODEL ONE) 'BIG 4'
1955 NORTON DOMINATOR 88/99 CAFE RACER
1981 KAWASAKI Z1000ST SHAFT
1988 KAWASAKI VN750 (UK) HARDTAIL + 5"
1988 KAWASAKI VULCAN 750 (US)
ALL TIME WISHLIST BIKES
1939 BROUGH SUPERIOR SS100 GRAND ALPINE SPORT
ANY 1940ish NORTON WITH CS1 ENGINE
A RIDE ON A NORTON NEMISIS 'A'
NEVER HAD A CAR LICENCE AND HOPFULLY NEVER WILL
EDALBRIS is offline
post #10 of 11 (permalink) Old 12-19-2006, 04:37 PM
fergy's Avatar
Do you have any photos posted up of your 750? I'd like to see it!
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
