Rear brakes - interesting colors? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 11-23-2006, 04:09 PM Thread Starter
Crobins365's Avatar
Broke into the rear brake assembly yesterday, and posted pics (Gallery under my name) of what I found. LOTS of earth tones - cleaned up with CRC cleaner (yikes that stuff's toxic!), but can anyone tell me what's breaking down to create that color? The pads have a little life left in them, but I'm pretty sure the drum is shot. Do I have to replace the entire rear wheel? <sigh>
Happy Thanksgiving, everyone!!
C
Crobins365 is offline
post #2 of 13 (permalink) Old 11-23-2006, 06:52 PM
The color you see is most likely just brake dust. I wouldn't worry too much about that.
As far as the drum, what size did you get when you measured it ?
7.086" - 7.093" is standard size. 7.116" is the recommended service limit, but you could go a little beyond that (with fresh pads)
post #3 of 13 (permalink) Old 11-23-2006, 08:45 PM Thread Starter
Crobins365's Avatar
Ummmm...I didn't measure the drum itself. Somehow that didn't dawn on me. But the rear of the bike is still totally disassembled ('cept I put the wheel back on after I lubed the splines), so I can check it in the a.m. Is it possible for the drum to just warp, though?
C
post #4 of 13 (permalink) Old 11-23-2006, 09:42 PM
93VN750's Avatar
Cindy -
I doubt that the drum can warp as it is part of the wheel center and lots stronger than a regular drum brake.
From the pictures, looks like brake dust residue.
Clean it good with brake cleen and check as Hyper said above, if within spec, throw in some new shoes and adjust the linkage.
Should be good to go.
I honestly use my rear brake very little as the front is pretty stout, especially after the stainless lines went on. Mostly just use the rear to hold on a hill when stopped.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #5 of 13 (permalink) Old 11-24-2006, 03:11 PM
Geek
rnewell's Avatar
Took a look at the shoes. From what I can tell they look like they have plenty of meat left. I think if you just clean everything up they would be good.
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
post #6 of 13 (permalink) Old 11-25-2006, 09:16 AM Thread Starter
Crobins365's Avatar
I thought they looked okay, too, but what concerned me was the gap between the drum and the final drive and the brake side. I added a pic to my "rear brake" album (https://www.vn750.com/photopost/useralbums.php)
...hmmm. That link may not work. Okay, now i think I attached a pic to this message, but that may not have happened, either. Anyway, there's a small gap (2 mm) between the drum and the final drive, and a 1mm gap between the drum and the brake cover. That's what's making me think that there's a problem with the wheel overall - it's just not a very snug fit. So it may actually not be a problem with the brakes or the drum, but something else? Or maybe a gap like that isn't to be fretted about? I dunno - maybe my tolerances are lower than Kaw's.
C
post #7 of 13 (permalink) Old 11-25-2006, 10:46 AM
Search Goddess
Dianna's Avatar
Yes there is a small gap on both sides of the wheel, the final drive side a little more than the brake side. You have a real good example of this on your running bike. I think if you compare the two assembled you will see that they are about the same.
One note, if you by chance left one of the collars out or the large o-ring and tightened the wheel down, chances are it would lock up on you and not spin freely
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #8 of 13 (permalink) Old 11-26-2006, 09:16 AM Thread Starter
Crobins365's Avatar
You're right...although for some reason it looks like less of a gap on the drive side of my running bike. Hmmm. As for a missing collar, I checked the shaft before I put the wheel on (it spun) and checked it again after I put the wheel on (it spun, too). I'll keep mucking around with it - I still don't like the way the drum cover sits on the wheel (maybe that's warped??), but I could be looking for a problem where there's not one. It's just, ya know, the brakes...!
C
post #9 of 13 (permalink) Old 11-26-2006, 10:50 AM
93VN750's Avatar
But it is only your rear brake, which like I said, I rarely use. The fronts provide probably 90% of the stopping power on these bikes used correctly.
Just make sure that mechanically all else is right.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #10 of 13 (permalink) Old 11-26-2006, 01:25 PM Thread Starter
Crobins365's Avatar
I actually use my rear brake consistently, tho' I know that 3/4 of the stopping power comes from the front. But given the bike's weight, if I only use the front brake, I end up getting tossed forward a bit too much from momentum. I find I come to a more balanced halt with a steady rear brake application... and lord knows that some percentage of riding is looking good doin' it!
C
