Rear brake wear limit - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 21 (permalink) Old 11-21-2006, 07:28 AM Thread Starter
Crobins365's Avatar
Hi, Folks -
If my "wear limit" indicator on the rear brake is suggesting that a "replacement" is imminiently warranted...do I need new rear brake shoes? Pads? A drum? I haven't dismantled my rear set-up to see how the drum brake works (when I lubed the splines I tried not to disturb ancillary parts), but I was wondering if anyone had a quick answer to this question.
Thanks!
C
Crobins365 is offline
post #2 of 21 (permalink) Old 11-21-2006, 07:33 AM
Geek
rnewell's Avatar
Check it out soon. You don't want metal from a worn down shoe scraping up the drum in the rear wheel. The drum and rear wheel are one piece.
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
post #3 of 21 (permalink) Old 11-21-2006, 07:58 AM Thread Starter
Crobins365's Avatar
It's on my new project bike, and since I've dismantled most of the rear (well, okay, all of it), it's not even close to rideable at the moment. But I saw a couple of rear brake shoes on eBay and was wondering if that's what I need to replace. Come to think of it, though, what I did see of the rear was a true *drum*, not shoes. Is that right?
C
post #4 of 21 (permalink) Old 11-21-2006, 09:15 AM
Geek
rnewell's Avatar
The shoes are similar to the front pads. The drum is the inside of the wheel.
Ron from Jersey
HellFire windshield
Cobra exhaust
Side bags
rnewell is offline
post #5 of 21 (permalink) Old 11-21-2006, 09:49 AM Thread Starter
Crobins365's Avatar
Here's the eBay item number (190052996642). Sooooo, I need a drum *and* shoes? Or are these the wrong item altogether? I'm at work, and didn't bring my Clymer's with me...Perhaps I should just...work?
C
post #6 of 21 (permalink) Old 11-21-2006, 12:31 PM
Cindy disc brakes (like on the front) use brake pads, drums (like on the back) use brake shoes. if the shoes are worn, you could just replace them but keep in mind you should inspect the drum for wear...there are wear limits for the drums and also the discs
TrashLord is offline
post #7 of 21 (permalink) Old 11-21-2006, 12:59 PM Thread Starter
Crobins365's Avatar
The wear indicator on the outside of the drum (the arrow thing that marks "within limit") - that's for the shoes or the drum?
C
post #8 of 21 (permalink) Old 11-21-2006, 01:01 PM
Sky Rider's Avatar
The shoes. The drum will have to be measured by a set of calipers or similar tool. They measure the thickness of the drum wall.
How many miles does your project bike have on it? The rear brake should be good for a long time as the fronts supply most of the braking power.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #9 of 21 (permalink) Old 11-21-2006, 01:24 PM
Sky Rider's Avatar
Cindy,
here is part of the micro fiche for the rear end. I've marked the shoes so you will know what they look like.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
21480 Miles
VROC #8542
post #10 of 21 (permalink) Old 11-21-2006, 02:37 PM
The price of a new set of brake shoes is about $30.
Although the ones on ebay (which is what you'd need) don't look too bad, I'd say go with new.
