How to make foot brake taller - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 05-12-2013, 03:59 PM Thread Starter
Mod
Birdhunter02's Avatar
Been riding with Chads floor boards and just love them. Never had any before. Problem occurs when trying to brake. The pedal is as high as can go, and it only reaches the top of the foot board. Makes it difficult to really press down. Learned riding on dirt bikes, so that was always the go to brake. Now the front gets all the love.
Any suggestions?
TIA
Birdhunter02 is offline
post #2 of 18 (permalink) Old 05-12-2013, 06:15 PM
Have you adjusted the rear of the braking system At the rear wheel?
post #3 of 18 (permalink) Old 05-12-2013, 06:40 PM
x2! I looked at a pic on Chads' website and it looks like his brake pedal sits higher than the floor board. If there is a lot of travel before the rear brake kicks in, then adjust the nut forward some. Might want to put bike on center stand so you can spin the tire and gauge when the pads just touch the drum surface. If that's fine and it still travels too far, then the pads are too worn or the cable linkage is too stretched out and needs replacing.
post #4 of 18 (permalink) Old 05-12-2013, 06:49 PM
First off, to can adjust the pedal so it sits higher. You likely will need to re-adjust the brake cable at the wheel when your done.
And you can do what I did. Shape and bend a piece of metal to bolt on top of the pedal and cover it with a clutch pad from a small import:
http://www.flickr.com/photos/knifema...7602271287392/
post #5 of 18 (permalink) Old 05-12-2013, 06:52 PM
Nice work!
post #6 of 18 (permalink) Old 05-12-2013, 09:30 PM Thread Starter
Mod
Ahh. Thanks KM, Just what I was looking for.
post #7 of 18 (permalink) Old 05-12-2013, 10:11 PM
Okiebezer's Avatar
Hey! KM!! I like that idea! That could make a lot of difference in keeping solid grip on brake pedal when trying to apply pressure AND it looks ALOT better!
Okiebezer is offline
post #8 of 18 (permalink) Old 05-13-2013, 03:18 PM
I was going to suggest KM's mod for the brake pedal but he beat me to it...lol
I plan on doing this myself at some point.
If I recall correctly....at the botton of the brake lever there is a return stop that can be adjusted with a wrench(look under the fllorboard area). It stops the "up" travel or resting position of the brake lever.
Once you get the height set, you will need to adjust the rear drum adjustment like mentioned previously.
post #9 of 18 (permalink) Old 05-13-2013, 04:08 PM
Lol I just fixed this problem for a member. I cut a piece to bolt to the brake pedal and he is going to put a rubber pad on it.
post #10 of 18 (permalink) Old 05-13-2013, 07:39 PM
I lucked out and found a Kury pedal cover for a buck, just a guess but it raised the pad height at least 1/2" to 1".
Look at the pedal stop bolt and see how high it's sitting, as said, you can re-adjust the brakes if you move it. The bolt is under the rear of the pedal where it mounts to the footpeg.
