Brakes dragging after they get warm - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 05-05-2013, 05:26 PM Thread Starter
Hi I just recently got this bike from my soon to be father in law and it has been sitting for a few years. I bled the brakes and all that and they worked fine but once u ride for a bit they start to drag really bad to where I cant even push the bike. Bled it to free them up and they work fine for a little but the it seems the more I use it the more it wants to drag. Do they need to be rebuilt/replaced?
heeb2424 is offline
post #2 of 7 (permalink) Old 05-05-2013, 06:59 PM
JM2001's Avatar
Sounds like the caliper holder shafts are not working freely. This will cause the brakes to bind,especially when warm.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 7 (permalink) Old 05-05-2013, 07:10 PM
Sounds like a collapsing brake hose, but I don't know how common this is on our bikes.
I know it's pretty common on cars/trucks.
If it releases when you open the bleeder, that's a pretty good sign that the hose could be collapsing inside. You can't usually see the collapsed spot, the only option is to replace the hose.
Automotive master cylinders can fail and hold pressure, but I've never seen it happen on a bike.
post #4 of 7 (permalink) Old 05-05-2013, 07:56 PM
First thing i would do:
Remove calipers, disassemble, completely clean/degrease, reassemble.
+1
post #5 of 7 (permalink) Old 05-05-2013, 08:06 PM
If the caliper was hanging up on the bolts, I don't think opening the bleeder would release it.
post #6 of 7 (permalink) Old 05-06-2013, 10:08 PM Thread Starter
Yea I was gonna see if taking them apart and cleaning them might do the trick first and go from there. Just thought I would ask to see if anyone has ran into this problem before. Thanks fellas!
heeb2424 is offline
post #7 of 7 (permalink) Old 05-06-2013, 11:07 PM
Yeah, I had similar problem, I bled, ...and bled the brakes...finally disassembled / cleaned Calipers. Only then did the problem get resolved. About the same time, I also had a problem with the brake lever not returning completely, .....my brake light stayed on.
I discovered a tiny fluid/air return pinhole in the MC was blocked/plugged. After dis-assembly/cleaning of MC, problem resolved.
EDIT: You might consider cleaning both the calipers AND Master Cylinder, New Fluid, all in one shot.
hope this helps
+1
