Need to remove rotors to change tire? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 04-18-2013, 10:13 AM Thread Starter
Tech/Musician/Friendly
AudibleCreations's Avatar
Is it necessary to remove the rotors from the front tire if Im taking the wheel to get changed at a local bike shop?
2000 VN750(A16)
*Richmond, Va*
25,000 Miles
Jetted, Shaved, Coastered
New Petcock
New Fuel & Vacuum Lines
New Plugs
Spline Lube
ACCT to MCCT
New Oil in Final Drive
Acid & Naval Jelly'd Gas tank
Luggage Rack
Hard Saddle Bags
Extended b*%ch Seat
(time for a new rear tire and state inspection)
AudibleCreations is offline
post #2 of 13 (permalink) Old 04-18-2013, 10:41 AM
iirc......Yes, I believe so. If you don't, the tire shop will need to.
EDIT: oooop's i blew it ! ...CRS syndrome
post #3 of 13 (permalink) Old 04-18-2013, 10:55 AM
vnnikolouzo's Avatar
no,no the tire changer grabs the inside rim plenty of space
vnnikolouzo is offline
post #4 of 13 (permalink) Old 04-18-2013, 10:57 AM
Headbanger/Popes of Hell
ruger's Avatar
no. there is no need to remove rotors to have a tire changed.
ruger is offline
post #5 of 13 (permalink) Old 04-18-2013, 12:20 PM
post #6 of 13 (permalink) Old 04-18-2013, 12:38 PM
And you should only need to remove 1 caliper when you pull the wheel off. At least that's what's in the Clymers.
post #7 of 13 (permalink) Old 04-18-2013, 04:45 PM
Just a note: I've never had to remove a caliper either. Although, as easy as they come off, it would be easier to remount the wheel as lining up the disks can be annoying.
The darn brake pads move so easily.
post #8 of 13 (permalink) Old 04-18-2013, 04:59 PM
ruger's Avatar
yup. no need to remove a caliper, it can be done without removing one. although, if you wanted to, you could use that step. but it is not needed.
I believe "cindy" did a nice right up/walk through on how to remove the front wheel. maybe able to find it if you do a search.
ruger is offline
post #9 of 13 (permalink) Old 04-18-2013, 07:16 PM
knees in the breeze!!!
Tofer76's Avatar
i just did mine and all i had to do was deflate the tire down to give it wiggle room ( i have the bigger tire) but you should just have to pull the axel and slide it out
http://map.vulcan750.net/
VROC# 33976
1994 VN750
MODS SO FAR:
honda shadow 750 sissybar
ear shaved, K&N pods
142/42 jets, Cobra pipes
oversized tires, vn800 seat
vn750 rad cover, Tank bib
custom mirrors, gel battery
Tofer76 is offline
post #10 of 13 (permalink) Old 04-18-2013, 10:53 PM Thread Starter
I removed the calipers just for the fun of it. Working on the vn750 is probably the most therapeutic thing for me besides a coors light haha. Good info on the rotors guys, didn't want to have to take those off... those allen bolts are a bit tight!! Did anyone else notice how tight the speedo cable is? I feel like mine is stretched to the max but haven't had any problems from it.
2000 VN750(A16)
*Richmond, Va*
25,000 Miles
New Petcock
New Plugs
Spline Lube
ACCT to MCCT
Luggage Rack
Hard Saddle Bags
Extended b*%ch Seat
