Swingarm shafts - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 10-02-2006, 08:59 PM Thread Starter
OzKaw's Avatar
Question Swingarm shafts
While I have my bike in bits, I was planning on re-greasing the swingarm bearings, and giving the swingarm a quick coat of paint. The problem is that I canít get the swingarm shafts out from either side.
According to the manual, ďWhile holding the swingarm, pull out the swingarm shafts using a suitable bolt or screwĒ, it should be fairly easy, but Iím having no luck. Iíve already bent a couple of bolts that I used trying to lever it out, so Iím just about to give up on the idea of removing the swingarm.
Any advice??
Name:	Swingarm shaft.jpg
OzKaw is offline
post #2 of 13 (permalink) Old 10-02-2006, 11:59 PM
Once Banned
cegodsey's Avatar
No real advice. I don't know anybody that has ever done this. Just looking at the pic, the thought "flywheel puller" comes to mind. I'm sure it's probably not like that, though.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #3 of 13 (permalink) Old 10-03-2006, 03:03 AM
Ernie's Avatar
Send a message via MSN to Ernie
The shafts should not be that tight unless they have been in there for years without regular greasing. Mine came out fairly easily when I took the swingarm out to replace the driveshaft & final drive after the splines stripped. If yours are tight then you should be able to make up some sort of slide-hammer to attach to the M5 bolt that you screw into the shafts.
When replacing them make sure they are well greased, the same applies to the bearings. Also, you need to make sure the bearings are adjusted correctly.
1991 BMW K1100LT
1980 Suzuki GS1000G
Ernie is offline
post #4 of 13 (permalink) Old 10-03-2006, 04:32 AM
I'm with Ernie (from across the big pond) on the slide hammer attack.
It does look like a good bit of rust in there. Let some penetrating oil soak in for awhile, then try.
post #5 of 13 (permalink) Old 10-03-2006, 09:51 PM Thread Starter
OzKaw's Avatar
Thanks for the tips fellas.
I soaked them in some WD-40 overnight, and let rip with a mallet and some vice grips today. I managed to get the right side out without too much hassle, but the left side is proving to be a bit more stubborn. I might have to use a bigger hammer, lol..
As you can see from the pic, the R/H shaft has a fair amount of surface rust on it, so it's no wonder that they were so tight.
OzKaw is offline
post #6 of 13 (permalink) Old 10-04-2006, 01:19 AM
Ernie's Avatar
Yeah, I can see why you had so much trouble now. Hope you get the other one out OK - i'm sure you will with a bit of persistence.
I've often wondered why Kawasaki didn't drill & tap 2 M5 holes opposite each other so that the shaft can be pulled evenly rather than "one-sided". Obviously they couldn't put a hole in the middle because of where the adjuster bolt sits.
1991 BMW K1100LT
1980 Suzuki GS1000G
Ernie is offline
post #7 of 13 (permalink) Old 10-04-2006, 10:55 AM Thread Starter
OzKaw's Avatar
Talking Success
Well after 20 minutes or so of more hammering on the L/H shaft, I discovered that with one side removed, the swingarm can drop and slide off the remaining swingarm shaft. It was then easy to drive the left shaft from the inside out with a mallet.
With the swingarm shafts in such a rusty state, I imagine that the bearings canít be in very good shape either, so Iíll be getting them replaced while itís apart also.
I agree that having one tiny hole that's offset is definitely an odd design for removing the shafts. It seems that there's a few unusual designs on the VN, ( 4 cam chains on a V-twin??), but I guess it was engineered in the eighties.
OzKaw is offline
post #8 of 13 (permalink) Old 10-04-2006, 10:59 AM
Geek
rnewell's Avatar
They probably have a "Special" tool that you can purchase.
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
post #9 of 13 (permalink) Old 10-04-2006, 02:00 PM
I'm not sure about our vulcans, but with dirtbikes it takes the pressure off the swingarm bolt if you lift the rear tire a couple of inches.
But... sounds like you got it.
Mark is offline
post #10 of 13 (permalink) Old 10-04-2006, 02:43 PM
fergy's Avatar
Just one word: PB Blaster! (PB is not a word)
Probably would have made a huge difference over WD40.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
